Login Problem - Docker Compose - unable to login
I used the latest docker compose in github docker compose
I use open-core section of docker-compose above.
I replaced GRAYLOG_DATANODE_PASSWORD_SECRET and GRAYLOG_DATANODE_ROOT_PASSWORD_SHA2 as instructed in datanode and graylog section.
I spin up using docker-compose up -d
It is up in http://localhost:9000. I login using the password (I tried both value of password as clear text and as hash value) and it still fails.
I ssh into the container to check the /run/secret/ and there is no value there.
I confused on how to login. Please help
datanode:
image: “${DATANODE_IMAGE:-graylog/graylog-datanode:5.2}”
environment:
GRAYLOG_DATANODE_NODE_ID_FILE: “/var/lib/graylog-datanode/node-id”
GRAYLOG_DATANODE_PASSWORD_SECRET: “gj21DLc1h3M60fYlFZcBFu3QLvDuh6itBb6LozhpO48Yr5GOuN21YpW98isQoWh1rfMbcTT1zgmRiyNxmDsMthlcEs0Y4Uho”
GRAYLOG_DATANODE_ROOT_PASSWORD_SHA2: “d3bcc4ceb0547442ce0695dab9275880f29767de27b26783146be2b68d17207a”
GRAYLOG_DATANODE_MONGODB_URI: “mongodb://mongodb:27017/graylog”
graylog:
hostname: “server”
image: “${GRAYLOG_IMAGE:-graylog/graylog:5.2}”
depends_on:
mongodb:
condition: “service_started”
entrypoint: “/usr/bin/tini – /docker-entrypoint.sh”
environment:
GRAYLOG_NODE_ID_FILE: “/usr/share/graylog/data/data/node-id”
GRAYLOG_PASSWORD_SECRET: “gj21DLc1h3M60fYlFZcBFu3QLvDuh6itBb6LozhpO48Yr5GOuN21YpW98isQoWh1rfMbcTT1zgmRiyNxmDsMthlcEs0Y4Uho”
GRAYLOG_ROOT_PASSWORD_SHA2: “d3bcc4ceb0547442ce0695dab9275880f29767de27b26783146be2b68d17207a”
GRAYLOG_HTTP_BIND_ADDRESS: “0.0.0.0:9000”
GRAYLOG_HTTP_EXTERNAL_URI: “http://localhost:9000/”
GRAYLOG_MONGODB_URI: “mongodb://mongodb:27017/graylog”
I am also facing the same problem, but I installed mine on Ubuntu server!
What are y’all seeing? What do the docker logs (or local logs) say?
I believe you have to setup the datanode first before you can use graylog and the info about that is in the logs (either via docker logs, or the local log).
I just spun up the compose file and this is what i’m seeing:
first time setup
2024-01-03 19:13:13,046 INFO : org.graylog2.bootstrap.preflight.PreflightJerseyService -
It seems you are starting Graylog for the first time. To set up a fresh install, a setup interface has
been started. You must log in to it to perform the initial configuration and continue.
Initial configuration is accessible at 0.0.0.0:9000, with username 'admin' and password 'pdekzAtzRz'.
From there i’m brought through a workflow for setting up datanode (which is used instead of vanilla OpenSearch)
Hi Thanks for the reply.
I tried your suggestion to run docker logs
Then I get to see username & password that are provided; however this is NOT in the README.md thus I kept entering the password that i created using sha (as instructed) and graylog kept refusing me.
Thank you for your reply. Please fix the readme
