Logging Alert Notification
@dlancelin
Download from Github
View on Github
Issues
Stargazers
Plugin 4.1.0
Alert notification plugin for Graylog to generate log messages from alerts
The alert notification generate a log message when an alert is triggered.
Perfect for example to record alerts as internal log messages in Graylog itself using the Internal Logs Input Plugin for Graylog. Thus you can create a stream to receive and manage alerts.
Also perfect for example to forward alerts via log messages to a Security Incident Response Platform.
Please also take note that if message field values are included in the log message template and these values vary based on the messages that triggered the alert, then multiple log messages may be generated per alert.
