Is there any plugin that allows you to get ready-made alerts? The goal is to make the system a type of SIEM, and I would like instead of producing Alerts, to get a ready-made Alert template.
Tnx
Tnx
The offer of Graylog Illuminate is what you are looking for: https://www.graylog.org/illuminate/illuminate-authentication
