I use a different Graylog servers to collect logs from each site of my company.
I would like to forward some specific logs (not all) on Graylog B to Graylog A. Is it possible to do it in Graylog ?
Thanks for your help
he @chauchse
for that the kind of work the Graylog forwarder was created:
https://docs.graylog.org/en/3.2/pages/integrations/forwarder.html
he @chauchse
yes - no difference between “free” enterprise and enterprise. But, you need to install the integrations plugin: https://docs.graylog.org/en/3.2/pages/integrations.html
As it is mentioned in the documentation.
he @chauchse
your integrations plugin and the Graylog server need to be of the same version … sorry if the documentation is not clear on this. Will fix this asap.
Hi @jan
You’re right, a little tip on documentation about plugin version should be interesting.
It works perfectly now.
Thank you very much for your help.
