Limited for Stream and pipeline
Has Stream or Pipeline any limited for create in Graylog?
Can I create Stream or Pipeline without limitations???
Thank you for help me!
Do you mean in terms of the number you can create? I’ve seen no limits in the documents with a # value and I have made a ton (and seen other people add dozens and dozens). Just remember the more streams and pipelines, the more processing power that is needed, so it is more likely to come down to whether your hardware can handle the number of streams and pipelines you are using rather than graylog itself.
Great, i didn’t see nothing about limitations on create Stream or Pipeline. I want confirm with you in base to experience or use platform simply.
Thank a lot
