I have various question so here we go
What is the limit of graylog 5.0 Open source? I mean how many logs can graylog store in gigabytes, in time and before it overwrites the data? What is the traffic limit that graylog supports? What file do I have to copy to make a backup? Can logs be loaded from a file on disk without being sent by agents?
If anybody want tell me something more than this please tellme about that.
Graylog 5 Opensource limits are essentially only that you have no access to enterprise features.
The Opensource version doesn’t limit the amount of data you store, but archiving data (moving from hot to warm/cold storage) is an enterprise feature. You can store as much data as you have disk.
Graylog Opensource scales outward nicely, you can cluster Graylog/Mongo and cluster ElasticSearch (OpenSearch preferred) to scale accordingly. There are adjustments to your environment that you might need outside Graylog, such as perhaps a load balancer for the data coming in… you can find more on the clustering and balancing in the community forums
Graylog keeps its settings in MongoDB, the messages/data you receive is stored in Elasticsearch/OpenSearch - use tools for those DB’s to back them up, Graylog Opensource doesn’t have that.
Generally speaking you need an agent of some sort to pull data from files. Elastic Beats and NXlog are the two agent most used.
Thanks Mr tmacgbay, it means a lot to me.
graylog 5 + Opensearch 2.x + mongodb with beats and nxlog in production. Load balancer is optional if the size of the structure is small, don´t?
I am using filebeat and Nxlog with sidedecar with 4.3 graylog and elasticsearch 7.9.3 and mongodb 4.x beacuse my jobs is onlyone to take logs and I am using virtual box 7.0.4, all of this in laboratory environment.
if you want tell me more please I am all ears… hahahahahaha.
