LDAP Authentication SSLHandshakeException
I’m trying to setup LDAP authentication against eDirectory LDAP, Graylog is first 3-rd party, where I have any problem with SSL.
  • OS Information:
OpenSuse 15.5 Leap
  • Package Version:
5.5.2
I imported eDirectory CA into Java certification store. Tried start Graylog server with debug option, to see more detailed error message, but only information I get is when I test the connection on setup page with "IOException(LDAPException(resultCode=91 (connect error), errorMessage=‘An error occurred while attempting to establish a connection to server testserver.test.com:636: SSLHandshakeException(Received fatal alert: handshake_failure), ldapSDKVersion=6.0.10, revision=51b3c7fe15cf42d4b2cd3bbd8165ebf759a8277d’))
I’m unable to get more info from logs I set in /etc/sysconfig/graylog-server
GRAYLOG_SERVER_ARGS=“-d” , but even that in server log there isn’t any LDAP error message
I tried to add -Djavax.net.debug=all -Djava.security.debug=all , but this doesn’t add more verbose messages for SSL handshake.
Found the answer where to look for debug messages. Because in my case Graylog server is running under SystemD, all Java net debug messages are in journal log.
journalctl -u graylog-server
Is there a way to limit maximum TLS version, which is trying to negotiate ? Looks like there is problem with TLSv1.3. I tried setting it in java.security jdk.tls.disabledAlgorithms=TLSv1.3, but no change at all.
OK, I ended up with creating Haproxy LDAP proxy. :slightly_frowning_face:
