LD Path issue, graylog open v5
Java Path error preventing OpenSearch from working. Specific error:
Starting OpenSearch
/graylog/opensearch/jdk/bin/java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
libjli.so exists on the filesystem in the opensearch path, but that path is not part of the OS LD_PATH. Is the fix to simply add this to ld.so.conf?
Either way, the docs for installing on ubuntu don’t work in several areas. The Elastic vs. OpenSearch aspect is also a bit vague.
  • OS Information: Ubuntu LTS Server 22.04
  • Package Version:
    opensearch 2.0.1 tarball
Was about to add path to ld.so.conf and run ldconfig
What is the best solution, as I can think of at least two methods of solving this.
Hello && welcome @ritter6281
What I ended up doing was using this documention for install Opensearch 2.5/2.6
Like the following settings.
Hey @ritter6281
Then let the OpenSearch path become part of the LD path or set a symbolic link form opensearch-path to ld path.
e.g.
LD_LIBRARY_PATH=/usr/local/lib:/lib64:/opensearch/whatever/path
export LD_LIBRARY_PATH
