jrecho
(Echou)
July 9, 2023, 10:21pm
1
Syslog not receiving syslog messages
Ubuntu Latest
22.04
Latest greylog server open
I created an input on port 1514 and see that syslogs are coming to my Ubuntu server via tcpdump but geylog is not showing any messages
Am I missing something here
Here is what I see in my tcpdum.cap file
^Tb^B^B^B^B^C�7�<14>1 2023-07-09T18:10:29.366-04:00 gw3 RT_FLOW - RT_FLOW_SESSION_CREATE [source-address=“128.116.27.182” source-port=“24292” destination-address=“64.182.182.72” destin>
^T�
jrecho
(Echou)
July 9, 2023, 11:20pm
2
Is there anyway to force geylog to listen to port 514. Because I can not get my firewall to send the syslogs on ports 1514
ihe
July 10, 2023, 1:37pm
3
Graylog is written with an “a” and not an “e”.
Port 514 is below 1000, so only root-users should open ports there. A nginx as LB could redirect your ports.
If the messages do not pop up, but are visable in in/out on the top right, check your timezones.
jrecho
(Echou)
July 11, 2023, 1:10am
4
i changed the user to root and it now reads port 514
ihe
July 12, 2023, 9:00am
5
that’s not the best idea in regards to security.
jrecho
(Echou)
July 13, 2023, 12:30pm
6
The server is not exposed to the internet. Plus got the SRX to finally use port 1514 using this command
set security log stream Greylog host port 1514
Where Graylog could be your stream server name
ihe
July 13, 2023, 2:36pm
7
Still the same as 3 days ago
H077E
July 14, 2023, 9:14pm
8
please show the output of “show security log”. From configuration mode or “show configuration security log” from operational mode.
Show the output of “show system timezone” and from operational mode “show system uptime” or “run show system uptime” from configuration mode.
