Json Lists Help
I have a field that contains valid json wrapped in brackets, example: [{“Href”:“https[:]//protection[.]office[.]com/viewalerts?id=randomchars”,“Category”:null,“Label”:“alert”,“Type”:“webLink”}]
What is the best way to get this json parsed? Should I trim, do a replace [{ with { and }] with }, something else?
Any help would be appreciated.
Thanks,
You can use for example this snippet. If you want to prefix fields from json replace “prefix_” in function set_field and uncomment line and comment previous one.
rule "extract-json"
    has_field("json_field")
    let extractjson = regex(pattern: "\\[(\\{.*\\})\\]", value: to_string($message.json_field));
    let json = parse_json(to_string(extractjson["0"]));
    let map = to_map(json);
    set_fields(map);
    // Optionally add prefix "prefix_" to json fields
    //set_fields(map, "prefix_");
    // Optionally replace [:.] in URL in field prefix_Href
    //let fix_url = regex_replace("\\[(:|.)\\]", to_string($message.prefix_Href), "$1");
    //set_field("prefix_Href", fix_url);
    // Optionally remove field
    //remove_field("json_field");
    // Optionally rename one of the field
    //rename_field("prefix_Href", "URL");
Hey thanks for providing that snippet. I tried to use it and unfortunately it did not parse out the fields from that json list. Here is the updated snippet with the fields added in:
rule "normalize_entities"
    has_field("Entities")
    let extractjson = regex(pattern: "\\[(\\{.*\\})\\]", value: to_string($message.Entities));
    set_fields(map);
    set_fields(map, "entities_");
I’m not sure what I am missing here, but this looks correct based on the snippet you provided. I also ran the json list thru a regex checker using the regex you provided and seems like it should have worked. Any thoughts?
Thanks,
Please don’t use set_fields several times:
  1. If you want to create field names based on json, use line: set_fields(map);
  2. If you want to add prefix to field names, use line: set_fields(map, "entities_");
Use one of the line, but not both.
Try to debug, if regex works for you, add:
let debug_message = concat("Regex check: ", extractjson);
debug(debug_message);
And check graylog log file: /var/log/graylog-server/server.log
