JerseyService Failing
After checking the multitude already posted similar posts; I still cannot find the issue in my config files.
2022-08-22T08:33:00.222Z INFO  [ServiceManagerListener] Services are now stopped.
2022-08-22T08:33:00.222Z ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:769) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:581) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:295) ~[graylog.jar:?]
	at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:229) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:311) [graylog.jar:?]
	at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
	Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
	Caused by: java.net.BindException: Cannot assign requested address
		at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_342]
		at sun.nio.ch.Net.bind(Net.java:461) ~[?:1.8.0_342]
		at sun.nio.ch.Net.bind(Net.java:453) ~[?:1.8.0_342]
		at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:222) ~[?:1.8.0_342]
		at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:85) ~[?:1.8.0_342]
		at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bindToChannelAndAddress(TCPNIOBindingHandler.java:107) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bind(TCPNIOBindingHandler.java:64) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:215) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:195) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:186) ~[graylog.jar:?]
		at org.glassfish.grizzly.http.server.NetworkListener.start(NetworkListener.java:711) ~[graylog.jar:?]
		at org.glassfish.grizzly.http.server.HttpServer.start(HttpServer.java:256) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:204) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:158) ~[graylog.jar:?]
		at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
		at com.google.common.util.concurrent.Callables$4.run(Callables.java:121) ~[graylog.jar:?]
		at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_342]
my configuration file is the following (after "cat /etc/graylog/server/server.conf | egrep -v “^\s*(#|$)”):
is_leader = true
password_secret = z5spz1gwviuGbIRA5QIG4tF0fe3XkEkcZEd2be6DvfmhKRhSa0V7tQfIc4SU8ZvwuejkitFVs7fzMrbzJ1yaKgV90zoGBgiJ
root_password_sha2 = 6f21b79e2ffaea57d65335363c3473dd02e7d1f17d02fe4a4378b5bbee5d0af0
http_bind_address = 51.15.205.53:9000
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Edit: I am running this off a virtual machine located at the ip in http_bind_adress. It’s a Ubuntu machine; and I followed the guide here to install it on said machine.
Hello @Sovn
I looked over you config file, not seeing anything out of the ordinary, looks good.
Which java version do you use?
  • Ubuntu: apt-get install openjdk-8-jre-headless
Couple suggestions,
Make sure Graylog can access files and folders it needs. For example:
chown graylog:graylog -R /etc/graylog
Also check /etc/hosts file. For testing purposes something like this. You may need to restart your network service or reboot.
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
51.15.205.53 graylog.domain.com ### <--- put hostname here.
To find more clues on what’s going on I would check the Journalctl & post , example:
journalctl -u graylog
Ensure Elasticsearch/MongoDb is working.
What does the following command show?
systemctl status graylog-server
EDIT:
make sure that SELinux isn’t blocking the Java process to bind to any
network ports. Also make sure to check the local system logs in /var/log/, e. g. audit.log,
for related error messages.
BTW the reason I stated about your /etc/hosts file was this part of the error log.
Appreciate the support; the issue was that this was set at something other than 127.0.0.1
and i wasnt using the
http_external_uri = http://51.15.205.53:9000/
like this.
Now my server.log is being spammed of failed API Requests.
2022-08-22T15:12:55.936Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:55.940Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_0/_mapping] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:56.935Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:57.898Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:57.911Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.916Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.923Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.929Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:57.929Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.940Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_0/_stats] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:57.946Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/_alias/gl-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.952Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.958Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-events_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.963Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-events_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.968Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/_alias/gl-failures_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.973Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-failures_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.980Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-failures_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.985Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-failures_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.991Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/_alias/gl-system-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:57.997Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-system-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:58.005Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-system-events_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:58.010Z WARN  [RestClient] request [GET http://127.0.0.1:9200/gl-system-events_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:12:58.930Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:12:59.931Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:00.932Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:01.929Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:01.936Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:01.944Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_0/_mapping] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:02.930Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:03.934Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:04.930Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:05.929Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:06.930Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.887Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.896Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.897Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/graylog_*,gl-events_*,gl-failures_*,gl-system-events_*?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.903Z WARN  [RestClient] request [HEAD http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.905Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health/graylog_*,gl-events_*,gl-failures_*,gl-system-events_*?master_timeout=60s&level=cluster&timeout=60s] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.907Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.908Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/graylog_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.913Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.914Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.917Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-failures_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.923Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/gl-system-events_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.927Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_alias/restored-archive_deflector?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open%2Cclosed&allow_no_indices=true] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.928Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cat/nodes?format=json&h=id%2Cname%2Crole%2Chost%2Cip%2CfileDescriptorMax%2CdiskUsed%2CdiskTotal%2CdiskUsedPercent&full_id=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.928Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_*/_alias?ignore_throttled=false&ignore_unavailable=false&expand_wildcards=open&allow_no_indices=false] returned 2 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."],[299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices."]
2022-08-22T15:13:07.931Z WARN  [RestClient] request [GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
2022-08-22T15:13:07.935Z WARN  [RestClient] request [GET http://127.0.0.1:9200/graylog_0/_stats] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 "Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See https://www.elastic.co/guide/en/elasticsearch/reference/7.17/security-minimal-setup.html to enable security."]
If i follow the link and setup it; it makes Graylog unable to find the Elasticsearch version; so i removed the lines in the elasticsearch conf files.
I obviously cant reach the Web UI yet.
Your setting were correct the first time,
Also, I seen this,
[GET http://127.0.0.1:9200/_cluster/health?master_timeout=60s&level=cluster&timeout=60s&local=true] returned 1 warnings: [299 Elasticsearch-7.17.5-8d61b4f7ddf931f219e3745f295ed2bbc50c8e84 “Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See Set up minimal security for Elasticsearch | Elasticsearch Guide [7.17] | Elastic to enable security.”]
You have went beyond the supported version of Elasticsearch here. Other have also and was still functioning with some errors. If you cant get into Graylog WebUI this would be Network setting on this machine or permissions.
Here is my lab Elasticsearch-7.10 file
[root@graylog graylog_user]# cat /etc/elasticsearch/elasticsearch.yml | egrep -v "^\s*(#|$)"
cluster.name: graylog
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: 127.0.0.1
http.port: 9200
discovery.type: single-node
bootstrap.memory_lock: true
Here is my Network setting in Graylog
http_bind_address = 10.10.10.10:9000
Here is my host file.
[root@graylog graylog_user]# cat /etc/hosts
10.10.10.10 graylog-server.domain.com
Hope that helps
EDIT: I forgot to mention, Do you have apache, Nginx, etc… installed for load balancing?
