Graylog startup failed - Java IllegalStateException
Description of your problem
Graylog no longer starts correctly. When I restart the application I get the following error from server.log in /var/log/graylog-server/:
2021-09-27T17:16:04.349Z ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:773) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:585) ~[graylog.jar:?]
	at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:316) ~[graylog.jar:?]
	at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:166) [graylog.jar:?]
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:277) [graylog.jar:?]
	at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
	Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
	Caused by: java.net.SocketException: Permission denied
		at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_292]
		at sun.nio.ch.Net.bind(Net.java:461) ~[?:1.8.0_292]
		at sun.nio.ch.Net.bind(Net.java:453) ~[?:1.8.0_292]
		at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:222) ~[?:1.8.0_292]
		at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:85) ~[?:1.8.0_292]
		at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bindToChannelAndAddress(TCPNIOBindingHandler.java:107) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bind(TCPNIOBindingHandler.java:64) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:215) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:195) ~[graylog.jar:?]
		at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:186) ~[graylog.jar:?]
		at org.glassfish.grizzly.http.server.NetworkListener.start(NetworkListener.java:711) ~[graylog.jar:?]
		at org.glassfish.grizzly.http.server.HttpServer.start(HttpServer.java:256) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:202) ~[graylog.jar:?]
		at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:156) ~[graylog.jar:?]
		at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
		at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
		at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_292]
Description of steps you’ve taken to attempt to solve the issue
I’ve noticed that if I comment out the http_bind_address line from server.conf, the error does not appear and the server launches OK. However, I am unable to access the application.
My question is: why does this error occur if I have a http_bind_address set, and how can I fix it?
Environmental information
Ubuntu 20.04 LTS
Package versions
  • Graylog: 4.1.5
  • MongoDB: 1:3.6.9+really3.6.8+90~g8e540c0b6d-0ubuntu5.2
  • Elasticsearch: 7.10.2
I would attach both server.conf and server.log but they exceed the character limit on this forum, and I can’t attach them to be uploaded due to your restrictions on file types. Let me know if you need them, and if so, how best to share them.
Try this:
$ cat /etc/graylog/server/server.conf | egrep -v "^\s*(#|$)"
Looks like it is a permission denied on a socket exception - at least that’s what I read out of it. Maybe you have some other service/application using the Graylog port?
Thanks for your response. Below is the server.conf file with password hashes removed:
is_master = true
password_secret =
root_password_sha2 =
http_bind_address = 10.1.3.163:80
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
I’m not aware of any application using port 80 on this machine, but I suppose it is possible. I used sudo ss | grep :80 to check port 80 and it returned nothing. Is there anything else I can use to check?
Just to get things running, try binding to a different port, Graylog default is 9000…
http_bind_address = 10.1.3.163:9000
If that works fine then it’s just figuring what else you have going at :80
When using port 9000, the error message doesn’t appear, and the server appears the start correctly:
2021-09-29T14:15:29.187Z INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.1.5 [org.graylog.aws.AWSPlugin]
2021-09-29T14:15:29.189Z INFO  [CmdLineTool] Loaded plugin: Enterprise Integrations 4.1.5 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2021-09-29T14:15:29.190Z INFO  [CmdLineTool] Loaded plugin: Integrations 4.1.5 [org.graylog.integrations.IntegrationsPlugin]
2021-09-29T14:15:29.191Z INFO  [CmdLineTool] Loaded plugin: Collector 4.1.5 [org.graylog.plugins.collector.CollectorPlugin]
2021-09-29T14:15:29.192Z INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 4.1.5 [org.graylog.plugins.enterprise.EnterprisePlugin]
2021-09-29T14:15:29.192Z INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.1.5 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2021-09-29T14:15:29.193Z INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.1.5 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2021-09-29T14:15:29.193Z INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.1.5 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2021-09-29T14:15:29.194Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.1.5+01c9198 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2021-09-29T14:15:29.194Z INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.1.5+01c9198 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2021-09-29T14:15:29.217Z INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2021-09-29T14:15:29.328Z INFO  [Version] HV000001: Hibernate Validator null
2021-09-29T14:15:31.778Z INFO  [InputBufferImpl] Message journal is enabled.
2021-09-29T14:15:31.794Z INFO  [NodeId] Node ID: 086ea892-b443-4092-aff8-ca9e3cdf0f36
2021-09-29T14:15:31.958Z INFO  [LogManager] Loading logs.
2021-09-29T14:15:32.104Z INFO  [LogManager] Logs loading complete.
2021-09-29T14:15:32.107Z INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2021-09-29T14:15:32.130Z INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2021-09-29T14:15:32.162Z INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2021-09-29T14:15:32.227Z INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:42260}] to localhost:27017
2021-09-29T14:15:32.236Z INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 27]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=7186517}
2021-09-29T14:15:32.246Z INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:42261}] to localhost:27017
2021-09-29T14:15:32.415Z INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2021-09-29T14:15:32.803Z INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running v7.10.2
2021-09-29T14:15:33.350Z INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2021-09-29T14:15:33.410Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-09-29T14:15:33.416Z INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2021-09-29T14:15:33.427Z INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:42262}] to localhost:27017
2021-09-29T14:15:33.446Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-09-29T14:15:33.486Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-09-29T14:15:33.510Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-09-29T14:15:33.548Z WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2021-09-29T14:15:34.208Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2021-09-29T14:15:34.210Z INFO  [ServerBootstrap] Graylog server 4.1.5+01c9198 starting up
2021-09-29T14:15:34.210Z INFO  [ServerBootstrap] JRE: Private Build 1.8.0_292 on Linux 5.4.0-86-generic
2021-09-29T14:15:34.210Z INFO  [ServerBootstrap] Deployment: deb
2021-09-29T14:15:34.210Z INFO  [ServerBootstrap] OS: Ubuntu 20.04.3 LTS (focal)
2021-09-29T14:15:34.210Z INFO  [ServerBootstrap] Arch: amd64
2021-09-29T14:15:34.238Z INFO  [PeriodicalsService] Starting 36 periodicals ...
2021-09-29T14:15:34.239Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2021-09-29T14:15:34.255Z INFO  [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2021-09-29T14:15:34.321Z INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2021-09-29T14:15:34.321Z INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2021-09-29T14:15:34.323Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2021-09-29T14:15:34.326Z INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2021-09-29T14:15:34.326Z INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2021-09-29T14:15:34.329Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2021-09-29T14:15:34.331Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2021-09-29T14:15:34.331Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2021-09-29T14:15:34.331Z INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2021-09-29T14:15:34.332Z INFO  [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2021-09-29T14:15:34.337Z INFO  [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2021-09-29T14:15:34.337Z INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2021-09-29T14:15:34.342Z INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:42264}] to localhost:27017
2021-09-29T14:15:34.344Z INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:42263}] to localhost:27017
2021-09-29T14:15:34.351Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2021-09-29T14:15:34.351Z INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2021-09-29T14:15:34.353Z INFO  [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2021-09-29T14:15:34.368Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2021-09-29T14:15:34.371Z INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:42265}] to localhost:27017
2021-09-29T14:15:34.374Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2021-09-29T14:15:34.389Z INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:42267}] to localhost:27017
2021-09-29T14:15:34.391Z INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:42266}] to localhost:27017
2021-09-29T14:15:34.404Z INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2021-09-29T14:15:34.404Z INFO  [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2021-09-29T14:15:34.416Z INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2021-09-29T14:15:34.416Z INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2021-09-29T14:15:34.425Z INFO  [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2021-09-29T14:15:34.434Z INFO  [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2021-09-29T14:15:34.442Z INFO  [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2021-09-29T14:15:34.449Z INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2021-09-29T14:15:34.454Z INFO  [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2021-09-29T14:15:34.468Z INFO  [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2021-09-29T14:15:34.470Z INFO  [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2021-09-29T14:15:34.471Z INFO  [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2021-09-29T14:15:34.472Z INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseManagerPeriodical] periodical in [0s], polling every [300s].
2021-09-29T14:15:34.475Z INFO  [Periodicals] Starting [org.graylog.plugins.license.LicenseReportPeriodical] periodical in [300s], polling every [3600s].
2021-09-29T14:15:34.475Z INFO  [Periodicals] Starting [org.graylog.plugins.license.StagedLicenseInstallerPeriodical] periodical, running forever.
2021-09-29T14:15:34.475Z INFO  [Periodicals] Starting [org.graylog.plugins.auditlog.mongodb.MongoAuditLogPeriodical] periodical in [0s], polling every [3600s].
2021-09-29T14:15:34.476Z INFO  [Periodicals] Starting [org.graylog.plugins.report.scheduler.ReportPeriodical] periodical in [120s], polling every [60s].
2021-09-29T14:15:34.476Z INFO  [Periodicals] Starting [org.graylog.plugins.report.service.ChromeDriverCleanupPeriodical] periodical in [60s], polling every [180s].
2021-09-29T14:15:34.481Z ERROR [MongoAuditLogPeriodical] Not running cleanup for auditlog entries in MongoDB because there is no valid license.
2021-09-29T14:15:37.579Z INFO  [NetworkListener] Started listener bound to [10.1.3.163:9000]
2021-09-29T14:15:37.580Z INFO  [HttpServer] [HttpServer] Started.
2021-09-29T14:15:37.580Z INFO  [JerseyService] Started REST API at <10.1.3.163:9000>
2021-09-29T14:15:37.582Z INFO  [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=2, UserSessionTerminationService [RUNNING]=21, GracefulShutdownService [RUNNING]=69, LocalKafkaMessageQueueWriter [RUNNING]=69, UrlWhitelistService [RUNNING]=69, LocalKafkaMessageQueueReader [RUNNING]=70, LocalKafkaJournal [RUNNING]=74, OutputSetupService [RUNNING]=77, JobSchedulerService [RUNNING]=77, PrometheusExporter [RUNNING]=79, BufferSynchronizerService [RUNNING]=80, MongoDBProcessingStatusRecorderService [RUNNING]=100, EtagService [RUNNING]=122, ConfigurationEtagService [RUNNING]=131, StreamCacheService [RUNNING]=205, LookupTableService [RUNNING]=215, PeriodicalsService [RUNNING]=245, JerseyService [RUNNING]=3347}
2021-09-29T14:15:37.583Z INFO  [ServiceManagerListener] Services are healthy
2021-09-29T14:15:37.583Z INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2021-09-29T14:15:37.588Z INFO  [ServerBootstrap] Graylog server up and running.
2021-09-29T14:15:37.588Z ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2021-09-29T14:15:37.610Z INFO  [InputStateListener] Input [Syslog UDP/6118f4544e7ad752469d44ec] is now STARTING
2021-09-29T14:15:37.611Z INFO  [InputStateListener] Input [GELF UDP/6115f9304e7ad7524699f1e0] is now STARTING
2021-09-29T14:15:38.194Z WARN  [Bootstrap] Unknown channel option 'io.netty.channel.unix.UnixChannelOption#SO_REUSEPORT' for channel '[id: 0x84244b1d]'
2021-09-29T14:15:38.194Z WARN  [Bootstrap] Unknown channel option 'io.netty.channel.unix.UnixChannelOption#SO_REUSEPORT' for channel '[id: 0xb8717ac6]'
2021-09-29T14:15:38.231Z WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=Linux Syslog UDP, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=086ea892-b443-4092-aff8-ca9e3cdf0f36} (channel [id: 0xb8717ac6, L:/0:0:0:0:0:0:0:0:8514]) should be 262144 but is 212992.
2021-09-29T14:15:38.230Z WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=Windows UDP, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=086ea892-b443-4092-aff8-ca9e3cdf0f36} (channel [id: 0x84244b1d, L:/10.1.3.163:12201]) should be 262144 but is 212992.
2021-09-29T14:15:38.247Z INFO  [InputStateListener] Input [GELF UDP/6115f9304e7ad7524699f1e0] is now RUNNING
2021-09-29T14:15:38.250Z INFO  [InputStateListener] Input [Syslog UDP/6118f4544e7ad752469d44ec] is now RUNNING
But if I curl localhost:9000, I get “connection refused”:
curl: (7) Failed to connect to localhost port 9000: Connection refused
I can curl localhost:9200 and elasticsearch responds, so this looks like an issue with graylog. Let me know what else I can check.
I changed the port to 9000, and the application appears to start, but if I curl localhost:9000 I get “connection refused”. I can curl localhost:9200 I get elasticsearch responding, so I think this is an issue with graylog.
The log says the graylog server is up and running, and the service is active and running.
I tried responding with the log, but Akismet blocked the post.
Hey there. Catching up on the post, I’ll note that using :80 as your port is an antipattern. Anything below port 1024 is a privileged port and can’t be used without running Graylog as root, which we strongly recommend against unless you have a VERY good reason to do so.
When it comes to curling localhost:9000, you should see something like:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="robots" content="noindex, nofollow">
    <meta charset="UTF-8">
    <title>Graylog Web Interface</title>
    <link rel="shortcut icon" href="/assets/favicon.png">
  </head>
  <body>
    <script src="/config.js"></script>
    <script src="/assets/vendor.53480e037b0a599cf54a.js"></script>
    <script src="/assets/polyfill.909253c37b9ca88e70e0.js"></script>
    <script src="/assets/builtins.909253c37b9ca88e70e0.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.threatintel.ThreatIntelPlugin/plugin.org.graylog.plugins.threatintel.ThreatIntelPlugin.a0abb3099d310b99f981.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.enterprise.EnterprisePlugin/plugin.org.graylog.plugins.enterprise.EnterprisePlugin.b63e75ab4cd9f320dbfe.js"></script>
    <script src="/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/plugin.org.graylog.plugins.collector.CollectorPlugin.0fdc66dc14c3d97376e9.js"></script>
    <script src="/assets/plugin/org.graylog.integrations.IntegrationsPlugin/plugin.org.graylog.integrations.IntegrationsPlugin.ddab5280b42173b8f8fe.js"></script>
    <script src="/assets/plugin/org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin/plugin.org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin.f2c44f3a982ece74b1b2.js"></script>
    <script src="/assets/plugin/org.graylog.aws.AWSPlugin/plugin.org.graylog.aws.AWSPlugin.ba0c1ef29d3af8acf6f7.js"></script>
    <script src="/assets/app.909253c37b9ca88e70e0.js"></script>
  </body>
</html>
The fact that you don’t tells me that there’s something else at play here, maybe a firewall rule? Have you tried running netstat -ntlp | grep 9000 to see if Graylog is actually up and listening? I
f it’s showing up, then you should try running nc -vz localhost 9000 to see if you can successfully make a connection to Graylog. If that works, then I’d see if you have ufw running by using ufw status.
If none of those work, you’ll need to share your config.
I wasn’t aware running on port 80 wasn’t recommended, that’s fine, I can use a different port. My main issue is I’m still not getting a response through curl.
When I run sudo netstat -ntlp | grep 9000 I get:
tcp6 0 0 10.1.3.163:9000 :::* LISTEN 1380917/java
And for nc -vz localhost 9000 I get:
nc: connect to localhost port 9000 (tcp) failed: Connection refused
As I mentioned before I can curl 9200 and get a response from elastic search, so I think this is a graylog issue.
I get connection refused if I use localhost but if I use the hostname I get:
$ nc -vz G-Serv 9000
Connection to G-Serv 9000 port [tcp/*] succeeded!
same issue with curl. I have to use the hostname and not localhost.
I don’t see anywhere in the server.conf file you posted earlier where the elasticsearch_hosts is defined…
# requires authentication.
If it’s on the same machine you may still need to define it and use the server name. Just guessing.
Watch Graylog logs when you start the service
post anything new since you now have the service running…
It just occurred to me that I think your mongodb_uri is incorrect. You currently have it set to:
But given that MongoDB runs on 27017, your port is missing. It should look like:
mongodb_uri = mongodb://localhost:27017/graylog
This is likely why the curl’s failing–the API is attempting to start, but given that it’s not successfully making a connection to MongoDB, it’s not actually responding.
That’s really odd, but it seems to be the issue. If I use the IP with curl it works.
So everything seems to be working fine on port 9000 now, but I’d like to have the site on port 80. I know you don’t recommend the application running on port 80. So what’s the best practice for achieving this from your perspective?
Best practice is to use a reverse proxy like Apache or Nginx. I’ve posted some Nginx examples here Nginx Config Examples
