It is possible generate dinamyc dashboard?
Hi, i need to know the follow.
The purpose of this is generate dinamyc dashboard.
For example, the primary step is through query get the IPs of users that connect for others country distinct of Argentina.
This search (NOT ClientHost_country_code:AR) return some IPs.
My idea would be take this IPs returned and i do a second dashboard with this results that update dynamically.
The other dashboard should show the users that connect with this IPs obtained before.
Its possible this?
Thanks!
current stable version of Graylog does not allow this - but the upcoming 3.0 release will have something very similar.
