I am trying to set up a graylog server but I have issues with these two passwords:
I am running an ubuntu vm with the newest versions of graylog, mongoDB and opensearch.
Also the web-console looks weird to me.
The 4. screenshot contains the commands I used.
Thanks!
gsmith
(GSmith)
May 16, 2024, 3:24am
2
Hey @Domi.2109
Have you seen this documentation here
If not, try that see if it works.
Hi @gsmith
Everything was installed as described in the manual.
gsmith
(GSmith)
May 16, 2024, 10:08pm
4
Hey @Domi.2109
what I did was…
This is for password_secret.
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
ocFlg3phZ9lOMW6MKSioardY7xXd6Yz9WVrr6HBmynZivOVgrrsUe3hfFlNUSGO5xUUYRf8Foja58dRf-8PVsCtC6hkhYf0e
password_secret = ocFlg3phZ9lOMW6MKSioardY7xXd6Yz9WVrr6HBmynZivOVgrrsUe3hfFlNUSGO5xUUYRf8Foja58dRf-8PVsCtC6hkhYf0e
Then for root_password_sha2
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
Enter Password: password123
ef92b778bafe771e89245b89ecbc08a44a4e166c06659911881f383d4473e94f
Results:
root_password_sha2 = ef92b778bafe771e89245b89ecbc08a44a4e166c06659911881f383d4473e94f
Its not clear what you issue is.
Hey @gsmith ,
I could figure it out. The Problem was that i did not configure the elasticsearch parameter in the server.conf. Unfortunatly this was not documented and I wonder why this parameter exists, because you have to use opensearch.
Hi Domi, can you clarify what this means? As far as I can find, this parameter is documented via our docs site and specifically for the installation . Let us know if you have feedback on what we can improve.
system
(system)
Closed
May 31, 2024, 1:10pm
7
