Is it possible to keep the fromhost-ip after RSYSLOG transmits message
My Graylog Server is listening udp/514 by rsyslog service.
Rsyslog transmits messages when it receives any messages.
And I do the replace(let ipaddress replace source) as below picture:
The issue is:
the messages’ [gl2_remote_ip] field will replaced to RSYSLOG’s IP by RSYSLOG.
here is the config in my RSYSLOG:
*.* @10.162.102.124:1514;RSYSLOG_SyslogProtocol23Format
How can I do ?
replace the source IP in RSYSLOG?
@xuziheng1002
did you have preserved hostname set in rsyslog?
PreserveFQDN on
yes I did,but issue is not resolve.
Well, that’s exactly what the gl2_remote_ip is supposed to contain: The IP address of the client from which Graylog received the message.
If the message was received from rsyslog, then gl2_remote_ip will contain the IP address of the rsyslog server.
Using a Syslog UDP or TCP input on the other hand, will try to find the hostname contained in the actual syslog message and fill the source message field with it.
