"Invalid credentials, please verify ..." when using DNS for web, IP works
Hi all,
When attempting to log into Graylog’s web interface via a DNS entry I get the following error: “Invalid credentials, please verify them and retry.” However if I access the web interface by IP address I’m able to log in. I should also note the same issue happens when I go to a different DNS name that points to a reverse proxy. I’ve had this issue since 2.4 and I upgraded all the way to 3.3 today hoping that it would resolve the issue. Below is my config:
Graylog Config:
# Cluster settings
is_master = true
# General
dashboard_widget_default_cache_time = 10s
# Access secrets
password_secret = "redacted"
root_username = admin
root_email = redacted
root_timezone = EST
root_password_sha2 = redacted
# Plugins
# Proxies
trusted_proxies = 127.0.0.1/32, 10.10.10.0/24
# Web interface
http_bind_address = 10.10.10.123:9000
http_enable_cors = true
http_enable_gzip = false
http_publish_uri = http://master-chief.domain.com:9000/
http_external_uri = https://graylog.domain.com/
# Search options
allow_highlighting = false
# Elasticsearch
output_batch_size = 500
output_flush_interval = 1
# Elasticsearch http client (GL >= 2.3)
elasticsearch_hosts = http://master-chief:9200,http://cortana:9200,http://sgt-johnson:9200,http://arbiter:9200,http://lord-hood:9200,http://dr-halsey:9200,http://miranda-keys:9200
elasticsearch_max_total_connections = 20
elasticsearch_max_total_connections_per_route = 2
elasticsearch_discovery_enabled = true
# Processors
processbuffer_processors = 5
outputbuffer_processors = 3
async_eventbus_processors = 2
outputbuffer_processor_keep_alive_time = 5000
outputbuffer_processor_threads_core_pool_size = 3
outputbuffer_processor_threads_max_pool_size = 30
udp_recvbuffer_sizes = 1048576
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Message journal
message_journal_max_age = 12h
message_journal_max_size = 5gb
message_journal_flush_age = 1m
message_journal_flush_interval = 1000000
message_journal_segment_age = 1h
message_journal_segment_size = 100mb
# Timeouts
output_module_timeout = 10000
stale_master_timeout = 2000
shutdown_timeout = 30000
ldap_connection_timeout = 2000
http_connect_timeout = 5s
http_read_timeout = 10s
http_write_timeout = 10s
stream_processing_timeout = 2000
# Ring buffers
ring_size = 65536
# Load balancing
# Stream processing
stream_processing_max_faults = 3
# Intervals
# MongoDB Configuration
mongodb_uri = mongodb://graylog:redacted@guilty-spark.domain.com:27017/graylog
mongodb_max_connections = 100
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/1.0/pages/drools.html
# HTTP proxy for outgoing HTTP calls
# GC
# Collector
collector_inactive_threshold  = 1m
collector_expiration_threshold  = 14d
# Content packs
content_packs_loader_enabled = false
NGINX Reverse Proxy Conf:
server {
  listen                             80;
  server_name                 graylog.domain.com;
  location / {
    return 301                    https://$server_name$request_uri;
server {
  listen                         443 ssl http2;
  include                     /etc/nginx/ssl.conf;
  location / {
      proxy_set_header     Host $http_host;
      proxy_set_header     X-Forwarded-Host $host;
      proxy_set_header     X-Forwarded-Server $host;
      proxy_set_header     X-Forwarded-For $proxy_add_x_forwarded_for;
      proxy_set_header     X-Graylog-Server-URL https://$server_name/;
      proxy_pass                http://10.10.10.123:9000;
Environment Info:
I took a look at /etc/graylog/server/server.conf and didn’t see any errors. Any help is greatly appreciated, thank you!
So I understand the issue clearly…
you have a DNS A record for master-chief.domain.com that points to 10.10.10.123
you also have a DNS A record for graylog.domain.com that point to 10.10.10.122 (this is nginx)
you open your browser and want to be able to type https://graylog.domain.com and connect but that’s not working. Is that correct?
when you connect via IP you connect to 10.10.10.123:9000? http or https?
I ask because you proxy_pass line doesn’t indicate the https protocol…
PS - Halo much?
