Hello everyone,
Is there anyone here who is integrating Alienvault OTX into Graylog and using the associated rules?
I am currently at the point where I am enriching the log files with the following fields:
set_field(“threat_indicated”, intel.otx_threat_indicated);
set_field(“threat_ids”, intel.otx_threat_ids);
set_field(“threat_names”, intel.otx_threat_names);
However, I only see the field threat_indicated and not the IDs or names. The field threat_indicated shows as false. Does this mean that if it’s false, the IDs and names are not displayed? Or should the fields threat_ids and threat_names be displayed even if they are empty?
Additionally, I found the following error code in the server.log file:
2024-06-11T13:09:55.954+02:00 WARN [OTXDataAdapter] OTX IPv4 request for key <169.x.x.x> failed: Response{protocol=http/1.1, code=400, message=Bad Request, url=https://otx.alienvault.com//api/v1/indicators/IPv4/169.x.x.x/general}
if i go to the link with the IP Adress given in the server.log file i just get this:
“detail”: “IP is private.”
Does this error code correlate with the missing fields? How can I fix this issue? Does anyone have the error code 400 bad request error too?
Graylog Version:
Graylog 6.0.2
I Would appreciate it, if someone could help me please
Thank you very much in advance !
