Hello, does graylog have a connection API so that another application can call this API and receive feedback? I would like to integrate my system with graylog so that instead of searching for logs in graylog, I can do this in the system itself and generate a report with the information contained in that log.
Yes, anything you can do in the GUI you can do via api. Have a look at the api browser Graylog REST API if you only need to do simple things check out the simple search api as it lets you do everything in one api call.
Thank you for your help
