Hi Jochen,
Thank you for your reply.
There are logs below
sudo docker logs config_some-elasticsearch_1
    [2017-04-10 14:39:06,197][WARN ][bootstrap                ] unable to install syscall filter: seccomp unavailable: your kernel is buggy and you should upgrade
    [2017-04-10 14:39:07,440][INFO ][node                     ] [Baron Strucker] version[2.4.4], pid[1], build[fcbb46d/2017-01-03T11:33:16Z]
    [2017-04-10 14:39:07,447][INFO ][node                     ] [Baron Strucker] initializing ...
    [2017-04-10 14:39:11,157][INFO ][plugins                  ] [Baron Strucker] modules [reindex, lang-expression, lang-groovy], plugins [], sites []
    [2017-04-10 14:39:11,276][INFO ][env                      ] [Baron Strucker] using [1] data paths, mounts [[/usr/share/elasticsearch/data (/dev/mapper/SRVWEB03--vg-root)]], net usable_space [267.4mb], net total_space [10.7gb], spins? [possibly], types [ext4]
    [2017-04-10 14:39:11,277][INFO ][env                      ] [Baron Strucker] heap size [1015.6mb], compressed ordinary object pointers [true]
    [2017-04-10 14:39:25,744][INFO ][node                     ] [Baron Strucker] initialized
    [2017-04-10 14:39:25,752][INFO ][node                     ] [Baron Strucker] starting ...
    [2017-04-10 14:39:26,368][INFO ][transport                ] [Baron Strucker] publish_address {172.18.0.2:9300}, bound_addresses {[::]:9300}
    [2017-04-10 14:39:26,420][INFO ][discovery                ] [Baron Strucker] graylog/h2CcecesRl6AKhCg0ROcmw
    [2017-04-10 14:39:29,865][INFO ][cluster.service          ] [Baron Strucker] new_master {Baron Strucker}{h2CcecesRl6AKhCg0ROcmw}{172.18.0.2}{172.18.0.2:9300}, reason: zen-disco-join(elected_as_master, [0] joins received)
    [2017-04-10 14:39:29,941][INFO ][http                     ] [Baron Strucker] publish_address {172.18.0.2:9200}, bound_addresses {[::]:9200}
    [2017-04-10 14:39:29,947][INFO ][node                     ] [Baron Strucker] started
    [2017-04-10 14:39:30,367][INFO ][gateway                  ] [Baron Strucker] recovered [1] indices into cluster_state
    [2017-04-10 14:39:38,896][INFO ][cluster.routing.allocation] [Baron Strucker] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_0][3], [graylog_0][3], [graylog_0][2], [graylog_0][0], [graylog_0][0]] ...]).
    [2017-04-10 14:40:00,382][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 267.2mb[2.4%], shards will be relocated away from this node
    [2017-04-10 14:40:00,386][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [high disk watermark exceeded on one or more nodes]
    [2017-04-10 14:40:12,650][INFO ][cluster.service          ] [Baron Strucker] added {{graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{GYaP5Z11RS6HO2tV-FpeSg}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false},}, reason: zen-disco-join(join from node[{graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{GYaP5Z11RS6HO2tV-FpeSg}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false}])
    [2017-04-10 14:40:30,908][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 287.2mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:41:01,119][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 287.1mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:41:01,119][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [high disk watermark exceeded on one or more nodes]
    [2017-04-10 14:41:31,339][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 286.7mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:42:01,784][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 286.3mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:42:01,785][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [high disk watermark exceeded on one or more nodes]
    [2017-04-10 14:42:32,134][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 285.9mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:43:02,397][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 285.6mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:43:02,399][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [high disk watermark exceeded on one or more nodes]
    [2017-04-10 14:43:32,677][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 285.3mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:44:02,966][WARN ][cluster.routing.allocation.decider] [Baron Strucker] high disk watermark [90%] exceeded on [h2CcecesRl6AKhCg0ROcmw][Baron Strucker][/usr/share/elasticsearch/data/graylog/nodes/0] free: 285mb[2.6%], shards will be relocated away from this node
    [2017-04-10 14:44:02,967][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [high disk watermark exceeded on one or more nodes]
    [2017-04-10 14:45:02,393][INFO ][cluster.service          ] [Baron Strucker] removed {{graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{GYaP5Z11RS6HO2tV-FpeSg}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false},}, reason: zen-disco-node-failed({graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{GYaP5Z11RS6HO2tV-FpeSg}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false}), reason(transport disconnected)
    [2017-04-10 14:45:03,357][INFO ][cluster.routing.allocation.decider] [Baron Strucker] rerouting shards: [one or more nodes has gone under the high or low watermark]
    [2017-04-10 14:45:58,434][INFO ][cluster.service          ] [Baron Strucker] added {{graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{FHF9sEzeR0moZoSs6s9hMA}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false},}, reason: zen-disco-join(join from node[{graylog-a9c798f5-10e1-4c3b-a6a1-3dfa486b1ea4}{FHF9sEzeR0moZoSs6s9hMA}{172.18.0.4}{172.18.0.4:9350}{client=true, data=false, master=false}])
