Graylog search issue
I was running Graylog 2.x on-prem for a year+ and it ran well without issues for a long time. I’m using it as a simple searchable log repository for my firewall logs. I eventually ran into a systems issue with it and decided to rebuild from scratch in AWS. The replacement instance is up and running on Ubuntu 18.04 using Graylog 3.0.0.
The new system is receiving logs from my firewalls (firewall source: Cisco ASA’s, Input: RAW UDP).
Unfortunately, I seem to have issues with searching with the system. My primary use case would be to search for IP addresses that I would want to see firewall traffic logs for. When I try to search for IP’s now, I get nothing. However, the system does seem to be ingesting properly - I see the index counts rising steadily.
Any suggestions as to how to troubleshoot?
My /var/log/graylog-server/server.log file keeps generating the following types of content:
2019-03-26T20:00:19.082Z WARN [Messages] Failed to index message: index=<graylog_110> id= error=<{“type”:“cluster_block_exception”,“reason”:“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];”}>
2019-03-26T20:00:19.082Z ERROR [Messages] Failed to index [500] messages. Please check the index error log in your web interface for the reason. Error: One or more of the items in the Bulk request failed, check BulkResult.getItems() for more information.cd
Thanks,
Tariq
did you checked your elasticsearch logs?
my idea is that you do not have enough space and elasticsearch 6 made the index read-only because it hits the low watermark.
df shows:
Filesystem 1K-blocks Used Available Use% Mounted on
udev 8105732 0 8105732 0% /dev
tmpfs 1623552 2196 1621356 1% /run
/dev/nvme0n1p1 101583780 49813840 51753556 50% /
tmpfs 8117756 0 8117756 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 8117756 0 8117756 0% /sys/fs/cgroup
/dev/loop0 13056 13056 0 100% /snap/amazon-ssm-agent/495
/dev/loop1 93312 93312 0 100% /snap/core/6531
/dev/loop2 90112 90112 0 100% /snap/core/5328
/dev/loop3 18304 18304 0 100% /snap/amazon-ssm-agent/1068
/dev/loop4 93184 93184 0 100% /snap/core/6405
tmpfs 1623548 0 1623548 0% /run/user/1000
I haven’t done anything fancy to shift the install from the package defaults. I believe it’s all going to / and there appears to be 50GB left there. I did expand on the drive from it’s initial sizing, I believe it was 50GB to start and I expanded it to 100GB.
/var/log/elasticsearch has the following files:
drwxr-x— 2 elasticsearch elasticsearch 4096 Mar 26 20:04 .
drwxrwxr-x 15 root syslog 4096 Mar 27 06:25 …
-rw-r–r-- 1 elasticsearch elasticsearch 67109550 Mar 18 05:03 gc.log.0
-rw-r–r-- 1 elasticsearch elasticsearch 2810784 Mar 27 16:06 gc.log.0.current
-rw-r–r-- 1 elasticsearch elasticsearch 16357876 Mar 20 00:51 gc.log.1.current
-rw-r–r-- 1 elasticsearch elasticsearch 9327 Mar 15 00:00 graylog-2019-03-14-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 4642 Mar 16 00:52 graylog-2019-03-15-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 8189 Mar 17 03:02 graylog-2019-03-16-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 977 Mar 18 00:18 graylog-2019-03-17-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 12639 Mar 19 00:00 graylog-2019-03-18-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 2194 Mar 20 00:51 graylog-2019-03-19-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 12281 Mar 21 00:00 graylog-2019-03-20-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 2307 Mar 26 20:04 graylog-2019-03-21-1.log.gz
-rw-r–r-- 1 elasticsearch elasticsearch 212857 Mar 26 20:05 graylog.log
-rw-r–r-- 1 elasticsearch elasticsearch 2887291 Mar 26 20:47 graylog_deprecation.log
-rw-r–r-- 1 elasticsearch elasticsearch 0 Mar 14 01:29 graylog_index_indexing_slowlog.log
-rw-r–r-- 1 elasticsearch elasticsearch 0 Mar 14 01:29 graylog_index_search_slowlog.log
tail -50 of the graylog.log shows the following:
    at org.elasticsearch.action.search.AbstractSearchAsyncAction.executeNextPhase(AbstractSearchAsyncAction.java:153) ~[elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.FetchSearchPhase.moveToNextPhase(FetchSearchPhase.java:206) ~[elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.FetchSearchPhase.lambda$innerRun$2(FetchSearchPhase.java:104) ~[elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.CountedCollector.countDown(CountedCollector.java:53) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.CountedCollector.onFailure(CountedCollector.java:76) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.FetchSearchPhase$2.onFailure(FetchSearchPhase.java:173) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.ActionListenerResponseHandler.handleException(ActionListenerResponseHandler.java:53) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.action.search.SearchTransportService$ConnectionCountingHandler.handleException(SearchTransportService.java:462) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.transport.TransportService$ContextRestoreResponseHandler.handleException(TransportService.java:1103) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.transport.TransportService$6.doRun(TransportService.java:660) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:759) [elasticsearch-6.6.2.jar:6.6.2]
    at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:37) [elasticsearch-6.6.2.jar:6.6.2]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_191]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_191]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191]
[2019-03-26T20:04:39,209][INFO ][o.e.n.Node ] [FGUZb68] stopped
[2019-03-26T20:04:39,210][INFO ][o.e.n.Node ] [FGUZb68] closing …
[2019-03-26T20:04:39,230][INFO ][o.e.n.Node ] [FGUZb68] closed
[2019-03-26T20:05:04,844][INFO ][o.e.e.NodeEnvironment ] [FGUZb68] using [1] data paths, mounts [[/ (/dev/nvme0n1p1)]], net usable_space [49.5gb], net total_space [96.8gb], types [ext4]
[2019-03-26T20:05:04,847][INFO ][o.e.e.NodeEnvironment ] [FGUZb68] heap size [990.7mb], compressed ordinary object pointers [true]
[2019-03-26T20:05:05,493][INFO ][o.e.n.Node ] [FGUZb68] node name derived from node ID [FGUZb682QGGRBFobpyu-jQ]; set [node.name] to override
[2019-03-26T20:05:05,494][INFO ][o.e.n.Node ] [FGUZb68] version[6.7.0], pid[802], build[oss/deb/8453f77/2019-03-21T15:32:29.844721Z], OS[Linux/4.15.0-1034-aws/amd64], JVM[Oracle Corporation/OpenJDK 64-Bit Server VM/1.8.0_191/25.191-b12]
[2019-03-26T20:05:05,494][INFO ][o.e.n.Node ] [FGUZb68] JVM arguments [-Xms1g, -Xmx1g, -XX:+UseConcMarkSweepGC, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.io.tmpdir=/tmp/elasticsearch-8684823813574339173, -XX:+HeapDumpOnOutOfMemoryError, -XX:HeapDumpPath=/var/lib/elasticsearch, -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log, -XX:+PrintGCDetails, -XX:+PrintGCDateStamps, -XX:+PrintTenuringDistribution, -XX:+PrintGCApplicationStoppedTime, -Xloggc:/var/log/elasticsearch/gc.log, -XX:+UseGCLogFileRotation, -XX:NumberOfGCLogFiles=32, -XX:GCLogFileSize=64m, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/etc/elasticsearch, -Des.distribution.flavor=oss, -Des.distribution.type=deb]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [aggs-matrix-stats]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [analysis-common]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [ingest-common]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [ingest-geoip]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [ingest-user-agent]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [lang-expression]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [lang-mustache]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [lang-painless]
[2019-03-26T20:05:06,537][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [mapper-extras]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [parent-join]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [percolator]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [rank-eval]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [reindex]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [repository-url]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [transport-netty4]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] loaded module [tribe]
[2019-03-26T20:05:06,538][INFO ][o.e.p.PluginsService ] [FGUZb68] no plugins loaded
[2019-03-26T20:05:12,149][INFO ][o.e.d.DiscoveryModule ] [FGUZb68] using discovery type [zen] and host providers [settings]
[2019-03-26T20:05:12,659][INFO ][o.e.n.Node ] [FGUZb68] initialized
[2019-03-26T20:05:12,659][INFO ][o.e.n.Node ] [FGUZb68] starting …
[2019-03-26T20:05:13,078][INFO ][o.e.t.TransportService ] [FGUZb68] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2019-03-26T20:05:16,235][INFO ][o.e.c.s.MasterService ] [FGUZb68] zen-disco-elected-as-master ([0] nodes joined), reason: new_master {FGUZb68}{FGUZb682QGGRBFobpyu-jQ}{hsZ_Cp10R321xSDJMnOoCQ}{127.0.0.1}{127.0.0.1:9300}
[2019-03-26T20:05:16,240][INFO ][o.e.c.s.ClusterApplierService] [FGUZb68] new_master {FGUZb68}{FGUZb682QGGRBFobpyu-jQ}{hsZ_Cp10R321xSDJMnOoCQ}{127.0.0.1}{127.0.0.1:9300}, reason: apply cluster state (from
master [master {FGUZb68}{FGUZb682QGGRBFobpyu-jQ}{hsZ_Cp10R321xSDJMnOoCQ}{127.0.0.1}{127.0.0.1:9300} committed version [1] source [zen-disco-elected-as-master ([0] nodes joined)]])
[2019-03-26T20:05:16,284][INFO ][o.e.h.n.Netty4HttpServerTransport] [FGUZb68] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2019-03-26T20:05:16,284][INFO ][o.e.n.Node ] [FGUZb68] started
[2019-03-26T20:05:17,247][INFO ][o.e.g.GatewayService ] [FGUZb68] recovered [50] indices into cluster_state
[2019-03-26T20:05:24,134][INFO ][o.e.c.r.a.AllocationService] [FGUZb68] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_61][1], [graylog_61][2]] …]).
tail -50 of the gc.log.0.current file shows:
2019-03-27T16:11:04.393+0000: 72362.036: Total time for which application threads were stopped: 0.0002143 seconds, Stopping threads took: 0.0000502 seconds
2019-03-27T16:11:06.075+0000: 72363.718: [GC (Allocation Failure) 2019-03-27T16:11:06.075+0000: 72363.718: [ParNew
Desired survivor size 17432576 bytes, new threshold 6 (max 6)
  • age 1: 431600 bytes, 431600 total
  • age 2: 13344 bytes, 444944 total
  • age 3: 688 bytes, 445632 total
    : 273371K->599K(306688K), 0.0042593 secs] 519745K->246974K(1014528K), 0.0043273 secs] [Times: user=0.02 sys=0.00, real=0.01 secs]
    2019-03-27T16:11:06.079+0000: 72363.722: Total time for which application threads were stopped: 0.0045746 seconds, Stopping threads took: 0.0000361 seconds
    2019-03-27T16:11:14.398+0000: 72372.041: Total time for which application threads were stopped: 0.0004605 seconds, Stopping threads took: 0.0002972 seconds
    2019-03-27T16:11:14.401+0000: 72372.044: Total time for which application threads were stopped: 0.0001657 seconds, Stopping threads took: 0.0000393 seconds
    2019-03-27T16:11:24.393+0000: 72382.036: Total time for which application threads were stopped: 0.0001858 seconds, Stopping threads took: 0.0000304 seconds
    2019-03-27T16:11:29.677+0000: 72387.320: [GC (Allocation Failure) 2019-03-27T16:11:29.677+0000: 72387.320: [ParNew
  • age 1: 667456 bytes, 667456 total
  • age 2: 144 bytes, 667600 total
  • age 4: 320 bytes, 667920 total
    : 273239K->771K(306688K), 0.0039145 secs] 519614K->247146K(1014528K), 0.0039866 secs] [Times: user=0.01 sys=0.00, real=0.00 secs]
    2019-03-27T16:11:29.681+0000: 72387.324: Total time for which application threads were stopped: 0.0042236 seconds, Stopping threads took: 0.0000417 seconds
    2019-03-27T16:11:34.394+0000: 72392.037: Total time for which application threads were stopped: 0.0001682 seconds, Stopping threads took: 0.0000333 seconds
    2019-03-27T16:11:44.395+0000: 72402.038: Total time for which application threads were stopped: 0.0002155 seconds, Stopping threads took: 0.0000504 seconds
    2019-03-27T16:11:44.402+0000: 72402.045: Total time for which application threads were stopped: 0.0001781 seconds, Stopping threads took: 0.0000317 seconds
    2019-03-27T16:11:51.811+0000: 72409.454: [GC (Allocation Failure) 2019-03-27T16:11:51.811+0000: 72409.454: [ParNew
  • age 1: 723544 bytes, 723544 total
  • age 2: 6216 bytes, 729760 total
  • age 3: 64 bytes, 729824 total
  • age 5: 320 bytes, 730144 total
    : 273411K->840K(306688K), 0.0165914 secs] 519786K->247215K(1014528K), 0.0166842 secs] [Times: user=0.03 sys=0.00, real=0.01 secs]
    2019-03-27T16:11:51.828+0000: 72409.471: Total time for which application threads were stopped: 0.0169449 seconds, Stopping threads took: 0.0000312 seconds
    2019-03-27T16:11:54.394+0000: 72412.037: Total time for which application threads were stopped: 0.0001838 seconds, Stopping threads took: 0.0000344 seconds
    2019-03-27T16:12:04.393+0000: 72422.036: Total time for which application threads were stopped: 0.0001912 seconds, Stopping threads took: 0.0000444 seconds
    2019-03-27T16:12:14.390+0000: 72432.033: [GC (Allocation Failure) 2019-03-27T16:12:14.390+0000: 72432.033: [ParNew
  • age 1: 374584 bytes, 374584 total
  • age 2: 60856 bytes, 435440 total
  • age 3: 80 bytes, 435520 total
  • age 4: 64 bytes, 435584 total
  • age 6: 320 bytes, 435904 total
    : 273480K->620K(306688K), 0.0068328 secs] 519855K->246995K(1014528K), 0.0069079 secs] [Times: user=0.02 sys=0.00, real=0.00 secs]
    2019-03-27T16:12:14.397+0000: 72432.040: Total time for which application threads were stopped: 0.0071399 seconds, Stopping threads took: 0.0000310 seconds
    2019-03-27T16:12:14.401+0000: 72432.044: Total time for which application threads were stopped: 0.0002052 seconds, Stopping threads took: 0.0000587 seconds
    2019-03-27T16:12:14.407+0000: 72432.050: Total time for which application threads were stopped: 0.0001587 seconds, Stopping threads took: 0.0000259 seconds
    2019-03-27T16:12:24.394+0000: 72442.037: Total time for which application threads were stopped: 0.0004411 seconds, Stopping threads took: 0.0000420 seconds
    2019-03-27T16:12:34.394+0000: 72452.036: [GC (Allocation Failure) 2019-03-27T16:12:34.394+0000: 72452.037: [ParNew
  • age 1: 161648 bytes, 161648 total
  • age 2: 384 bytes, 162032 total
  • age 3: 80 bytes, 162112 total
  • age 5: 64 bytes, 162176 total
    : 273260K->424K(306688K), 0.0124344 secs] 519635K->246799K(1014528K), 0.0125396 secs] [Times: user=0.02 sys=0.00, real=0.01 secs]
Any hints at what’s happening from these snippets? How/where do I look for log entries that pertain to the low watermark?
Thanks,
Tariq
sorry as you did not format your posting in any way it is nearly unreadable.
OK. I can’t seem to get the formatting to look good for review. Perhaps we can start with the basics. Your recommendation had me examining the elasticsearch logs. I’m guessing the primary log repository for the elasticsearch install is in /var/log/elasticsearch. The /var/log/elasticsearch directory has the following files - which one(s) should I be looking through for watermark related content?
gc.log.0
gc.log.0.current
gc.log.1.current
graylog.log
Thanks,
Tariq
you could have answered that question by just look at the elasticsearch documentation …
… always the ${CLUSTERNAME}.log file …
OK.
I’m unsure of the “proper” method of formatting the output to make it more readable. Trying the “blockquote” option for the below. If there is a more preferred method, please let me know.
tail -30 /var/log/elasticsearch/graylog.log
[2019-03-26T20:05:16,240][INFO ][o.e.c.s.ClusterApplierService] [FGUZb68] new_master {FGUZb68}{FGUZb682QGGRBFobpyu-jQ}{hsZ_Cp10R321xSDJMnOoCQ}{127.0.0.1}{127.0.0.1:9300}, reason: apply cluster state (from master [master {FGUZb68}{FGUZb682QGGRBFobpyu-jQ}{hsZ_Cp10R321xSDJMnOoCQ}{127.0.0.1}{127.0.0.1:9300} committed version [1] source [zen-disco-elected-as-master ([0] nodes joined)]])
Thanks,
Tariq
if unsure, read the FAQ …
until the end all looks normal in your log.
