I think I striclty followed the documentation “docs.graylog.org/en/latest/pages/installation/os/debian.html”
I used deb packages, nothing from sources.
Here is the graylog-server :
root@graylog:~# grep -v -e “^#” -e “^\s*$” /etc/graylog/server/server.conf
is_master = true
password_secret = xxx
root_password_sha2 = xxx
rest_listen_uri = http[broke the link to bypass the 2 links limitation]://192.168.124.3:12900/
rest_transport_uri = http[broke the link to bypass the 2 links limitation]://192.168.124.3:12900/
web_listen_uri = http[broke the link to bypass the 2 links limitation]://192.168.124.3:9000/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
root@graylog:~#
Here is the elasticsearch conf (I only added the max_result_window because I red that my problem could come from here, but no improvement) :
root@graylog:~# grep -v -e “^#” -e “^\s*$” /etc/elasticsearch/elasticsearch.yml
cluster.name: graylog
max_result_window: 100000
root@graylog:~#
There are the ES startup logs :
==> /var/log/elasticsearch/graylog.log <==
[2017-03-24 13:48:59,314][INFO ][node
] [Guido Carosella] version[2.4.4], pid[3880],
build[fcbb46d/2017-01-03T11:33:16Z]
[2017-03-24 13:48:59,315][INFO ][node ] [Guido Carosella] initializing ...
[2017-03-24 13:48:59,742][INFO ][plugins
] [Guido Carosella] modules [reindex, lang-expression, lang-groovy],
plugins [], sites []
[2017-03-24 13:48:59,759][INFO ][env
] [Guido Carosella] using [1] data paths, mounts [[/var
(/dev/mapper/graylog--vg-var)]], net usable_space [738mb], net
total_space [1.4gb], spins? [possibly], types [ext4]
] [Guido Carosella] heap size [1007.3mb], compressed ordinary object
pointers [true]
[2017-03-24 13:49:01,308][INFO ][node ] [Guido Carosella] initialized
[2017-03-24 13:49:01,309][INFO ][node ] [Guido Carosella] starting ...
[2017-03-24 13:49:01,377][INFO ][transport
] [Guido Carosella] publish_address {127.0.0.1:9300}, bound_addresses
{[::1]:9300}, {127.0.0.1:9300}
[2017-03-24 13:49:01,381][INFO ][discovery ] [Guido Carosella] graylog/eqK8JCiqTVCQ-nGeOZPSAQ
[2017-03-24 13:49:04,451][INFO ][cluster.service
] [Guido Carosella] new_master {Guido
Carosella}{eqK8JCiqTVCQ-nGeOZPSAQ}{127.0.0.1}{127.0.0.1:9300}, reason:
zen-disco-join(elected_as_master, [0] joins received)
[2017-03-24 13:49:04,483][INFO ][http
] [Guido Carosella] publish_address {127.0.0.1:9200}, bound_addresses
{[::1]:9200}, {127.0.0.1:9200}
[2017-03-24 13:49:04,484][INFO ][node ] [Guido Carosella] started
[2017-03-24 13:49:04,526][INFO ][gateway ] [Guido Carosella] recovered [1] indices into cluster_state
[2017-03-24 13:49:04,978][INFO ][cluster.routing.allocation] [Guido
Carosella] Cluster health status changed from [RED] to [GREEN] (reason:
[shards started [[graylog_0][0], [graylog_0][2], [graylog_0][1],
[graylog_0][0]] ...]).
And there are the graylog-server logs :
http://pastebin.com/yCJx0HhT
Tell me if you need any information.
