Hi.
After upgrade to 3.3 GL interface on the right top corner is reporting only numbers of incoming/outgoing messages only for the current node of a cluster.
Someone else sees it too, or something is wrong in my cluster?
Thx
can you share a little about your setup? How many nodes? How many MongoDB Serves? Replicaset?
@jan
Sure I can. It is a small three-node cluster running Debian 10. This three nodes are running mongo 4.2 in 4.0 compatibility, all are in the same replica set. Nothing else is present on the server. Three nodes Elastic cluster is separated from the GL. Nodes are running 3.3 GL on 9000 default port. Nginx in proxy configuration is doing redirection from 80 to 433 and then proxy to 9000.
Access to the nodes is without NLB. I’m just using DNS Round Robin and using Beat with logstash output and load-balancing. Some of the three nodes are targets of the syslog UDP stream which is not balanced across the nodes. So some of the nodes are processing small numbers and some larger number of messages.
server.conf
is_master = true
password_secret = ***
root_username = ***
root_password_sha2 = ***
root_email = ***
root_timezone = ***
http_bind_address = 10.20.XXX.YYY:9000
trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128, 10.20.XXX.YYY/32
elasticsearch_hosts = http://10.20.XXX.YYY:9200,http://10.20.XXX.YYY:9200,http://10.20.XXX.YYY:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 3
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 3
outputbuffer_processors = 2
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = /graylog/journal/journal
mongodb_uri = mongodb://graylog:***@gl1.domain.local:27017,gl2.domain.local:27017,gl3.domain.local:27017/graylog?replicaSet=rs0
nginx.conf
server {
listen 10.20.XXX.YYY:443 ssl http2;
server_name gl1.domain.local 10.20.XXX.YYY graylog.domain.local;
ssl_certificate /etc/nginx/ssl/cert.pem;
ssl_certificate_key /etc/nginx/ssl/key.pem;
ssl on;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_protocols TLSv1.2;
ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
ssl_prefer_server_ciphers on;
location / {
proxy_set_header X-Graylog-Server-URL https://$server_name/;
proxy_pass http://10.20.XXX.YYY:9000;
if you go to the System > Nodes page - did you see all details from all nodes as it should or did you see for all nodes the same?
he @fangycz
sorry that I wasn’t clear.
I meand do all Nodes have unique information presented in the overview or are all the same? From what I can see all nodes report unique is that true?
But in addition:
in 3.3.1 this issue will be fixed
Hi @jan
When I open separate browser for each node, it seems they are reporting the same throughput which belongs to gl master. On the other hand as you can see in the nodes view, they are reporting the correct throughput for each node. In my setup the second node is target for syslog from Cisco ASA firewall.
@jan
About the bug, yes the behavior is the same. But just as I said before, it seems in my setup, that all the nodes are reporting throughput of the master.
