In N / Out 0 msgs/s
I know that this title is repeated among questions mutiple times, but I could not resolve the problem using them.
Elasticsearch cluster and indexers are reported to be fine, there is a lot of available disk space and here is the thread dump:
"main" id=1 state=WAITING
    - waiting on <0x408e96d9> (a java.lang.Thread)
    - locked <0x408e96d9> (a java.lang.Thread)
    at java.lang.Object.wait(Native Method)
    at java.lang.Thread.join(Thread.java:1245)
    at java.lang.Thread.join(Thread.java:1319)
    at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:168)
    at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:209)
    at org.graylog2.bootstrap.Main.main(Main.java:44)
"Reference Handler" id=2 state=WAITING
    - waiting on <0x3174fff5> (a java.lang.ref.Reference$Lock)
    - locked <0x3174fff5> (a java.lang.ref.Reference$Lock)
    at java.lang.Object.wait(Object.java:502)
    at java.lang.ref.Reference.tryHandlePending(Reference.java:191)
    at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:153)
"Finalizer" id=3 state=WAITING
    - waiting on <0x6063f7db> (a java.lang.ref.ReferenceQueue$Lock)
    - locked <0x6063f7db> (a java.lang.ref.ReferenceQueue$Lock)
    at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:143)
    at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:164)
    at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
"Signal Dispatcher" id=5 state=RUNNABLE
"inputbufferprocessor-0" id=15 state=WAITING
    - waiting on <0x285a518c> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x285a518c> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at sun.misc.Unsafe.park(Native Method)
    at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
    at com.lmax.disruptor.BlockingWaitStrategy.waitFor(BlockingWaitStrategy.java:45)
    at com.lmax.disruptor.ProcessingSequenceBarrier.waitFor(ProcessingSequenceBarrier.java:56)
    at com.lmax.disruptor.WorkProcessor.run(WorkProcessor.java:148)
    at com.codahale.metrics.InstrumentedThreadFactory$InstrumentedRunnable.run(InstrumentedThreadFactory.java:66)
    at java.lang.Thread.run(Thread.java:745)
"inputbufferprocessor-1" id=16 state=WAITING
"inputbufferprocessor-2" id=17 state=WAITING
    at com.lmax.disruptor.BatchEventProcessor.run(BatchEventProcessor.java:124)
"cluster-ClusterId{value='5ea08eb6b261710001f57825', description='null'}-mongo:27017" id=18 state=TIMED_WAITING
    - waiting on <0x02a1cdb1> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x02a1cdb1> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078)
    at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.waitForSignalOrTimeout(DefaultServerMonitor.java:222)
    at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.waitForNext(DefaultServerMonitor.java:203)
    at com.mongodb.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:151)
"CleanCursors-1-thread-1" id=19 state=TIMED_WAITING
    - waiting on <0x6565a28e> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x6565a28e> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1093)
    at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809)
    at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1067)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
"scheduled-daemon-0" id=21 state=WAITING
    - waiting on <0x434ae019> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x434ae019> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1088)
"scheduled-daemon-1" id=22 state=WAITING
"scheduled-daemon-2" id=23 state=WAITING
"outputbufferprocessor-0" id=24 state=WAITING
    - waiting on <0x78e02da6> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x78e02da6> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
"outputbufferprocessor-1" id=25 state=WAITING
    - waiting on <0x49bc7db4> (a java.util.concurrent.FutureTask)
    - locked <0x49bc7db4> (a java.util.concurrent.FutureTask)
    at java.util.concurrent.FutureTask.awaitDone(FutureTask.java:429)
    at java.util.concurrent.FutureTask.get(FutureTask.java:191)
    at com.google.common.util.concurrent.Uninterruptibles.getUninterruptibly(Uninterruptibles.java:142)
    at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:151)
    at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:51)
    at com.lmax.disruptor.WorkProcessor.run(WorkProcessor.java:143)
"outputbufferprocessor-2" id=26 state=WAITING
"scheduled-daemon-3" id=27 state=WAITING
"processbufferprocessor-0" id=28 state=TIMED_WAITING
    at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:338)
    at com.lmax.disruptor.MultiProducerSequencer.next(MultiProducerSequencer.java:137)
    at com.lmax.disruptor.MultiProducerSequencer.next(MultiProducerSequencer.java:105)
    at com.lmax.disruptor.RingBuffer.next(RingBuffer.java:253)
    at org.graylog2.plugin.buffers.Buffer.insert(Buffer.java:59)
    at org.graylog2.buffers.OutputBuffer.insertBlocking(OutputBuffer.java:100)
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.handleMessage(ProcessBufferProcessor.java:117)
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.dispatchMessage(ProcessBufferProcessor.java:100)
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:77)
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42)
"processbufferprocessor-1" id=29 state=TIMED_WAITING
"processbufferprocessor-2" id=30 state=TIMED_WAITING
"processbufferprocessor-3" id=31 state=TIMED_WAITING
"processbufferprocessor-4" id=32 state=TIMED_WAITING
"scheduled-daemon-4" id=33 state=WAITING
"eventbus-handler-0" id=34 state=WAITING
    - waiting on <0x2770b00b> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x2770b00b> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    at java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:442)
"InputSetupService" id=36 state=WAITING
    - waiting on <0x6cbe4200> (a java.util.concurrent.CountDownLatch$Sync)
    - locked <0x6cbe4200> (a java.util.concurrent.CountDownLatch$Sync)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer.parkAndCheckInterrupt(AbstractQueuedSynchronizer.java:836)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireSharedInterruptibly(AbstractQueuedSynchronizer.java:997)
    at java.util.concurrent.locks.AbstractQueuedSynchronizer.acquireSharedInterruptibly(AbstractQueuedSynchronizer.java:1304)
    at java.util.concurrent.CountDownLatch.await(CountDownLatch.java:231)
    at com.google.common.util.concurrent.Uninterruptibles.awaitUninterruptibly(Uninterruptibles.java:57)
    at org.graylog2.shared.initializers.InputSetupService.run(InputSetupService.java:95)
    at com.google.common.util.concurrent.AbstractExecutionThreadService$1$2.run(AbstractExecutionThreadService.java:66)
    at com.google.common.util.concurrent.Callables$4.run(Callables.java:122)
"JournalReader" id=39 state=TIMED_WAITING
    at org.graylog2.shared.buffers.ProcessBuffer.insertBlocking(ProcessBuffer.java:104)
    at org.graylog2.shared.journal.JournalReader.run(JournalReader.java:166)
"output-setup-service-0" id=43 state=WAITING
    - waiting on <0x4e6c532e> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x4e6c532e> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
"scheduled-daemon-5" id=46 state=WAITING
"scheduled-0" id=45 state=WAITING
    - waiting on <0x4a5a6a7f> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
    - locked <0x4a5a6a7f> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
"scheduled-1" id=48 state=WAITING
The problem resovled temporarily when I try to restart the containers (I’m using docker for that).
Can you give me a clue to follow?
I my case it was a GROK in my pipeline that went into infinite loop and eventually sucekd up all graylog resources. Here is the post where work done by @jrunu found the problem - with any luck it will help you…
