/var/log/elasticsearch/graylog.log
[2022-09-13T16:43:55,299][INFO ][o.e.n.Node ] [elastic] version[7.10.2], pid[23900], build[default/deb/747e1cc71def077253878a59143c1f785afa92b9/2021-01-13T00:42:12.435326Z], OS[Linux/5.15.0-47-generic/amd64], JVM[AdoptOpenJDK/OpenJDK 64-Bit Server VM/15.0.1/15.0.1+9]
[2022-09-13T16:43:55,305][INFO ][o.e.n.Node ] [elastic] JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]
[2022-09-13T16:43:55,305][INFO ][o.e.n.Node ] [elastic] JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Djava.locale.providers=SPI,COMPAT, -Xms8g, -Xmx8g, -XX:+UseG1GC, -XX:G1ReservePercent=25, -XX:InitiatingHeapOccupancyPercent=30, -Djava.io.tmpdir=/tmp/elasticsearch-6742182947013026966, -XX:+HeapDumpOnOutOfMemoryError, -XX:HeapDumpPath=/var/lib/elasticsearch, -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -XX:MaxDirectMemorySize=4294967296, -Des.path.home=/usr/share/elasticsearch,
-Des.path.conf=/etc/elasticsearch, -Des.distribution.flavor=default, -Des.distribution.type=deb, -Des.bundled_jdk=true]
[2022-09-13T16:43:57,485][WARN ][o.e.x.w.Watcher ] [elastic] the [action.auto_create_index] setting is configured to be restrictive [.watches,.triggered_watches,.watcher-history-*]. for the next 6 months daily history indices are allowed to be created, but please make sure that any future history indices after 6 months with the pattern [.watcher-history-yyyy.MM.dd] are allowed to be created
[2022-09-13T16:43:57,915][INFO ][o.e.p.PluginsService ] [elastic] loaded module [aggs-matrix-stats]
[2022-09-13T16:43:57,915][INFO ][o.e.p.PluginsService ] [elastic] loaded module [analysis-common]
[2022-09-13T16:43:57,916][INFO ][o.e.p.PluginsService ] [elastic] loaded module [constant-keyword]
[2022-09-13T16:43:57,916][INFO ][o.e.p.PluginsService ] [elastic] loaded module [flattened]
[2022-09-13T16:43:57,916][INFO ][o.e.p.PluginsService ] [elastic] loaded module [frozen-indices]
[2022-09-13T16:43:57,917][INFO ][o.e.p.PluginsService ] [elastic] loaded module [ingest-common]
[2022-09-13T16:43:57,917][INFO ][o.e.p.PluginsService ] [elastic] loaded module [ingest-geoip]
[2022-09-13T16:43:57,917][INFO ][o.e.p.PluginsService ] [elastic] loaded module [ingest-user-agent]
[2022-09-13T16:43:57,917][INFO ][o.e.p.PluginsService ] [elastic] loaded module [kibana]
[2022-09-13T16:43:57,918][INFO ][o.e.p.PluginsService ] [elastic] loaded module [lang-expression]
[2022-09-13T16:43:57,918][INFO ][o.e.p.PluginsService ] [elastic] loaded module [lang-mustache]
[2022-09-13T16:43:57,918][INFO ][o.e.p.PluginsService ] [elastic] loaded module [lang-painless]
[2022-09-13T16:43:57,919][INFO ][o.e.p.PluginsService ] [elastic] loaded module [mapper-extras]
[2022-09-13T16:43:57,919][INFO ][o.e.p.PluginsService ] [elastic] loaded module [mapper-version]
[2022-09-13T16:43:57,919][INFO ][o.e.p.PluginsService ] [elastic] loaded module [parent-join]
[2022-09-13T16:43:57,919][INFO ][o.e.p.PluginsService ] [elastic] loaded module [percolator]
[2022-09-13T16:43:57,920][INFO ][o.e.p.PluginsService ] [elastic] loaded module [rank-eval]
[2022-09-13T16:43:57,920][INFO ][o.e.p.PluginsService ] [elastic] loaded module [reindex]
[2022-09-13T16:43:57,920][INFO ][o.e.p.PluginsService ] [elastic] loaded module [repositories-metering-api]
[2022-09-13T16:43:57,921][INFO ][o.e.p.PluginsService ] [elastic] loaded module [repository-url]
[2022-09-13T16:43:57,921][INFO ][o.e.p.PluginsService ] [elastic] loaded module [search-business-rules]
[2022-09-13T16:43:57,921][INFO ][o.e.p.PluginsService ] [elastic] loaded module [searchable-snapshots]
[2022-09-13T16:43:57,921][INFO ][o.e.p.PluginsService ] [elastic] loaded module [spatial]
[2022-09-13T16:43:57,922][INFO ][o.e.p.PluginsService ] [elastic] loaded module [systemd]
[2022-09-13T16:43:57,922][INFO ][o.e.p.PluginsService ] [elastic] loaded module [transform]
[2022-09-13T16:43:57,922][INFO ][o.e.p.PluginsService ] [elastic] loaded module [transport-netty4]
[2022-09-13T16:43:57,922][INFO ][o.e.p.PluginsService ] [elastic] loaded module [unsigned-long]
[2022-09-13T16:43:57,923][INFO ][o.e.p.PluginsService ] [elastic] loaded module [vectors]
[2022-09-13T16:43:57,923][INFO ][o.e.p.PluginsService ] [elastic] loaded module [wildcard]
[2022-09-13T16:43:57,923][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-analytics]
[2022-09-13T16:43:57,924][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-async]
[2022-09-13T16:43:57,924][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-async-search]
[2022-09-13T16:43:57,924][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-autoscaling]
[2022-09-13T16:43:57,925][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-ccr]
[2022-09-13T16:43:57,925][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-core]
[2022-09-13T16:43:57,925][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-data-streams]
[2022-09-13T16:43:57,925][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-deprecation]
[2022-09-13T16:43:57,926][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-enrich]
[2022-09-13T16:43:57,926][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-eql]
[2022-09-13T16:43:57,926][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-graph]
[2022-09-13T16:43:57,927][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-identity-provider]
[2022-09-13T16:43:57,927][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-ilm]
[2022-09-13T16:43:57,927][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-logstash]
[2022-09-13T16:43:57,927][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-ml]
[2022-09-13T16:43:57,928][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-monitoring]
[2022-09-13T16:43:57,928][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-ql]
[2022-09-13T16:43:57,928][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-rollup]
[2022-09-13T16:43:57,928][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-security]
[2022-09-13T16:43:57,929][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-sql]
[2022-09-13T16:43:57,929][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-stack]
[2022-09-13T16:43:57,929][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-voting-only-node]
[2022-09-13T16:43:57,929][INFO ][o.e.p.PluginsService ] [elastic] loaded module [x-pack-watcher]
[2022-09-13T16:43:57,930][INFO ][o.e.p.PluginsService ] [elastic] no plugins loaded
[2022-09-13T16:43:57,969][INFO ][o.e.e.NodeEnvironment ] [elastic] using [1] data paths, mounts [[/graylog-data (/dev/mapper/graylog--data--vg-graylog--data)]], net usable_space [409.4gb], net total_space [806gb], types [ext4]
[2022-09-13T16:43:57,969][INFO ][o.e.e.NodeEnvironment ] [elastic] heap size [8gb], compressed ordinary object pointers [true]
[2022-09-13T16:43:58,131][INFO ][o.e.n.Node ] [elastic] node name [elastic], node ID [jXplRySTQxW_WDlSA02XUw], cluster name [graylog], roles [transform, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]
[2022-09-13T16:44:01,834][INFO ][o.e.x.m.p.l.CppLogMessageHandler] [elastic] [controller/24093] [Main.cc@114] controller (64 bit): Version 7.10.2 (Build 40a3af639d4698) Copyright (c) 2021 Elasticsearch BV
[2022-09-13T16:44:02,776][INFO ][o.e.t.NettyAllocator ] [elastic] creating NettyAllocator with the following configs: [name=elasticsearch_configured, chunk_size=1mb, suggested_max_allocation_size=1mb, factors={es.unsafe.use_netty_default_chunk_and_page_size=false, g1gc_enabled=true, g1gc_region_size=4mb}]
[2022-09-13T16:44:02,854][INFO ][o.e.d.DiscoveryModule ] [elastic] using discovery type [single-node] and seed hosts providers [settings]
[2022-09-13T16:44:03,260][WARN ][o.e.g.DanglingIndicesState] [elastic] gateway.auto_import_dangling_indices is disabled, dangling indices will not be automatically detected or imported and must be managed manually
[2022-09-13T16:44:03,605][INFO ][o.e.n.Node ] [elastic] initialized
[2022-09-13T16:44:03,607][INFO ][o.e.n.Node ] [elastic] starting ...
[2022-09-13T16:44:03,726][INFO ][o.e.t.TransportService ] [elastic] publish_address {10.0.221.16:9300}, bound_addresses {0.0.0.0:9300}
[2022-09-13T16:44:03,978][INFO ][o.e.c.c.Coordinator ] [elastic] cluster UUID [04NbFYPNQXm9OtdD5yFE2w]
[2022-09-13T16:44:04,121][INFO ][o.e.c.s.MasterService ] [elastic] elected-as-master ([1] nodes joined)[{elastic}{jXplRySTQxW_WDlSA02XUw}{FD1twWNDSSmoPh3Ahogmew}{10.0.221.16}{10.0.221.16:9300}{cdhilmrstw}{ml.machine_memory=8334688256, xpack.installed=true, transform.node=true, ml.max_open_jobs=20} elect leader, _BECOME_MASTER_TASK_, _FINISH_ELECTION_], term: 2, version: 117, delta: master node changed {previous [], current [{elastic}{jXplRySTQxW_WDlSA02XUw}{FD1twWNDSSmoPh3Ahogmew}{10.0.221.16}{10.0.221.16:9300}{cdhilmrstw}{ml.machine_memory=8334688256, xpack.installed=true, transform.node=true, ml.max_open_jobs=20}]}
[2022-09-13T16:44:04,185][INFO ][o.e.c.s.ClusterApplierService] [elastic] master node changed {previous [], current [{elastic}{jXplRySTQxW_WDlSA02XUw}{FD1twWNDSSmoPh3Ahogmew}{10.0.221.16}{10.0.221.16:9300}{cdhilmrstw}{ml.machine_memory=8334688256, xpack.installed=true, transform.node=true, ml.max_open_jobs=20}]}, term: 2, version: 117, reason: Publication{term=2, version=117}
[2022-09-13T16:44:04,221][INFO ][o.e.h.AbstractHttpServerTransport] [elastic] publish_address {10.0.221.16:9200}, bound_addresses {0.0.0.0:9200}
[2022-09-13T16:44:04,221][INFO ][o.e.n.Node ] [elastic] started
[2022-09-13T16:44:04,542][INFO ][o.e.l.LicenseService ] [elastic] license [4e52af05-bf04-4329-aaed-6ac3d1824ef9] mode [basic] - valid
[2022-09-13T16:44:04,546][INFO ][o.e.g.GatewayService ] [elastic] recovered [5] indices into cluster_state
[2022-09-13T16:44:05,643][INFO ][o.e.c.r.a.AllocationService] [elastic] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_0][0]]]).
elastic health
curl -X GET "localhost:9200/_cluster/health?pretty"
"cluster_name" : "graylog",
"status" : "green",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 18,
"active_shards" : 18,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 0,
"active_shards_percent_as_number" : 100.0
Does anyone have an idea what might be wrong or where I might check why the processing isn’t working?
