I have problem with manual log import to graylog with collector sidecar.
I need to import 3-5gb data on weekly base to graylog, I get raw/plain logs in multiple folders ziped and when put it in read folder of sidecar collector he send data to graylog but not all data because he send as GELF. How to setup a nxlog to send plain/raw data and then parse in graylog.
On live import I send plain/raw data and then parse in graylog and work like a charm.
My nxlog conf.
define ROOT /usr/bin
<Extension gelf>
Module xm_gelf
</Extension>
<Extension 5a26a74cc194d60889e14bb9-multiline>
Module xm_multiline
HeaderLine /^-./
</Extension>
<Extension 5a27b096c194d60443c4626f-multiline>
Module xm_multiline
HeaderLine /^\d{4}-\d{2}-\d{2}/
</Extension>
<Processor 5a26a74cc194d60889e14bb9-buffer>
Module pm_buffer
MaxSize 16384
Type Mem
</Processor>
<Processor 5a27b096c194d60443c4626f-buffer>
Module pm_buffer
MaxSize 16384
Type Mem
</Processor>
User nxlog
Group nxlog
Moduledir /usr/lib/nxlog/modules
CacheDir /var/spool/collector-sidecar/nxlog
PidFile /var/run/graylog/collector-sidecar/nxlog.pid
define LOGFILE /var/log/graylog/collector-sidecar/nxlog.log
LogFile %LOGFILE%
LogLevel INFO
<Extension logrotate>
Module xm_fileop
<Schedule>
When @daily
Exec file_cycle('%LOGFILE%', 7);
</Schedule>
</Extension>
<Input 5a26a74cc194d60889e14bb9>
Module im_file
File '/swisslog/*.log*'
PollInterval 30
SavePos True
ReadFromLast True
Recursive True
RenameCheck True
Exec $FileName = file_name(); # Send file name with each message
InputType 5a26a74cc194d60889e14bb9-multiline
</Input>
<Input 5a27b096c194d60443c4626f>
Module im_file
File '/swisslog/*.txt*'
PollInterval 6
SavePos True
ReadFromLast True
Recursive True
RenameCheck True
InputType 5a27b096c194d60443c4626f-multiline
</Input>
<Output 5a26a719c194d60889e14b81>
Module om_tcp
Host 172.16.11.110
Port 5045
OutputType GELF_TCP
Exec $short_message = $raw_event; # Avoids truncation of the short_message field.
Exec $gl2_source_collector = 'f2ee341e-78b5-458d-bc30-38b32b81d85b';
Exec $collector_node_id = 'graylog-collector-sidecar';
Exec $Hostname = hostname_fqdn();
</Output>
<Output 5a27b070c194d60443c46243>
Module om_tcp
Host 172.16.11.110
Port 5055
OutputType GELF_TCP
</Output>
<Route route-0>
Path 5a26a74cc194d60889e14bb9 => 5a26a74cc194d60889e14bb9-buffer => 5a26a719c194d60889e14b81
</Route>
<Route route-1>
Path 5a27b096c194d60443c4626f => 5a27b096c194d60443c4626f-buffer => 5a27b070c194d60443c46243
</Route>
and my parser/pipeline stage 0 on graylog server
rule "itc5_extract_log"
has_field("message")
let message_field = to_string($message.message);
// grok expression
// Note: the expression must both match nornal syslog on the ITC and the syslog of the ITC logger
// "%{TIMESTAMP_ISO8601:timestamp} %{WORD:hostname;string} #%{SEQNUM:seqnum;int} %{WORD:facility;string} %{LOGLEVEL:loglevel;string} %{SYSLOGPROG:prog}: (\{%{BASE10NUM:millis}\} )?([\[](?<category>[^\]]*)\] [(](?<traceid>[^)]*)[)])?\s?%{GREEDYDATA:msg;string}
// example: let gr = grok(pattern, value, [only_named_captures]) : GrokMatch$GrokResult
let parsed_fields = grok(pattern: "%{TIMESTAMP_ISO8601:logtime} %{WORD:hostname;string} #%{SEQNUM:seqnum;int} %{WORD:facility;string} %{LOGLEVEL:loglevel;string} %{SYSLOGPROG:prog}: (\\{%{BASE10NUM:millis}\\} )?([\\[](?<category>[^\\]]*)\\] [(](?<traceid>[^)]*)[)])?\\s?%{GREEDYDATA:msg;string}", value: message_field);
set_fields(parsed_fields);
// set_field("debug", to_string(parsed_fields));
Please can someone help me with that!
