Implement HTTPs to an working Graylog5-Docker (PaloAlto-Certificates)
I have a running and working Graylog5 with docker. Now i will securing it with http. The graylog.conf is in a persistent directory so that i can modify them easylie.
Our PaloAlto can generate Certificates. We have create a .pem and a .crt file.
Please explane me: is it enough to put the files to the graylog system and modify the config - or is it neccessary to make the “java private store”-Steps in the article i find with google?
My .pem is following:
-----BEGIN CERTIFICATE-----
MIIDRTCCAi2gAwIBAgIFANaoVpcwDQYJKoZIhvcNAQELBQAwEzERMA8GA1UEAxMI
UGFsb0FsdG8wHhcNMjMwNDA1MTYxMDUxWhcNMzMwNDAyMTYxMDUxWjAeMRwwGgYD
aRvPHkvDW8ycnxenvdXjGvLZ6NDnBooXJg==
-----END CERTIFICATE-----
-----BEGIN ENCRYPTED PRIVATE KEY-----
MIIFLTBXBgkqhkiG9w0BBQ0wSjApBgkqhkiG9w0BBQwwHAQIJGZBDQ2nPasCAggA
MAwGCCqGSIb3DQIJBQAwHQYJYIZIAWUDBAEqBBCcY3h0jkdwniEbys9zTMvGBIIE
D4dgdBWnqzIDn38l2ZGez42Dgnji6KgJltcjd5NRei9g
-----END ENCRYPTED PRIVATE KEY-----
My .crt is following:
The graylog.conf changes are:
http_enable_tls = true
http_tls_cert_file = /usr/share/graylog/data/config/cert_server.crt
http_tls_key_file = /usr/share/graylog/data/config/cert_server.pem
http_tls_key_password = verysecretpasswort
Hello @MyKeySoftMK
Once you have certs you can use JAVA default keystore called CACERTS.
keytool -import -trustcacerts -file graylog-certificate.pem -alias graylog.domain.com -keystore cacerts
should be good .BTW JAVA default secert is “changeit” you can adjust the secert by…
keytool -storepasswd -keystore /path/to/java/keystore/cacerts
   Type “changeit”
   New-PASS Type “my_new_secert”
What errors do you see in your logs?
I using the Docker-Installation of Graylog5 with persistent Config-Files. In this directory i have put the key & cert File. The paths in the config is adaptet.
Must the Keytool execute in the host enviroment or in the docker subsystem?
Hey @MyKeySoftMK
You can use keykool on the sysytem. What I have done in the past was find the version of java being used then use locate for cacerts.
You can also use your own keystore but other configuration will be need as shown here
This was just for dev node, I was testing Graylog Docker out using docker-compose.
Example:
keytool -importcert -keystore /var/lib/docker/overlay2/10232988d366d673dd8b1e4f36b9493a623a216fb45a29b841579a9da74c7673/merged/usr/local/openjdk-11/lib/security/cacerts -storepass changeit -alias graylog_server  -file localhost.pem
I have import the .pem file. The Result is:
Diesem Zertifikat vertrauen? [Nein]:  Ja
Zertifikat wurde Keystore hinzugefügt
Then I adapt the http_enable_tls = true and try to restart
The container didn´t start again. Error in log is:
2023-04-13 04:43:27,113 INFO : org.graylog2.shared.initializers.ServiceManagerListener - Services are now stopped.
2023-04-13 04:43:27,117 ERROR: org.graylog2.bootstrap.ServerBootstrap - Graylog startup failed. Exiting. Exception was:
        at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:769) ~[graylog.jar:?]
        at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:581) ~[graylog.jar:?]
        at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:295) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:273) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:324) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:260) [graylog.jar:?]
        at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
        Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
Hey @MyKeySoftMK
Seams like you have a configuration issue. Can you show your docker-compose file?
version: "3.8"
services:
  mongodb:
    image: "mongo:5.0"
    volumes:
      - "mongodb_data:/data/db"
    restart: "on-failure"
  opensearch:
    image: "opensearchproject/opensearch:2.4.0"
    environment:
      - "OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g"
      - "bootstrap.memory_lock=true"
      - "discovery.type=single-node"
      - "action.auto_create_index=false"
      - "plugins.security.ssl.http.enabled=false"
      - "plugins.security.disabled=true"
    ulimits:
      memlock:
        hard: -1
        soft: -1
      nofile:
        soft: 65536
        hard: 65536
    volumes:
      - "os_data:/usr/share/opensearch/data"
  graylog:
    hostname: "server"
    image: "${GRAYLOG_IMAGE:-graylog/graylog-enterprise:5.0}"
    depends_on:
      opensearch:
        condition: "service_started"
      mongodb:
    entrypoint: "/usr/bin/tini -- wait-for-it opensearch:9200 --  /docker-entrypoint.sh"
    ports:
    - "5044:5044/tcp"   # Beats
    - "5140:5140/udp"   # Syslog
    - "5140:5140/tcp"   # Syslog
    - "5555:5555/tcp"   # RAW TCP
    - "5555:5555/udp"   # RAW TCP
    - "9000:9000/tcp"   # Server API
    #- "443:9000/tcp"    # Server API HTTPS
    - "12201:12201/tcp" # GELF TCP
    - "12201:12201/udp" # GELF UDP
    #- "10000:10000/tcp" # Custom TCP port
    #- "10000:10000/udp" # Custom UDP port
    - "13301:13301/tcp" # Forwarder data
    - "13302:13302/tcp" # Forwarder config
    volumes:
      - "graylog_data:/usr/share/graylog/data/data"
      - "graylog_journal:/usr/share/graylog/data/journal"
      - ./config:/usr/share/graylog/data/config
volumes:
  mongodb_data:
  os_data:
  graylog_data:
  graylog_journal:
Hey @MyKeySoftMK
I see now, your using your graylog.conf file instead
Maybe this might help
Here is my lab Graylgo config
volumes:
      - graylog_bin:/usr/share/graylog/bin
      - graylog_data:/usr/share/graylog/data
environment:
      # Container time Zone
      - TZ=America/Chicago
      - GRAYLOG_PASSWORD_SECRET=pJod1TRZAckHmqM2oQPqX1qnLVJS99jHm2DuCux2Bpiuu2XLT
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=ef92b778bafe771e892911881f383d4473e94f
      - GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
      - GRAYLOG_HTTP_EXTERNAL_URI=http://192.168.1.28:9000/
      - GRAYLOG_ROOT_TIMEZONE=America/Chicago
      - GRAYLOG_ROOT_EMAIL=greg.smith@domain.com
      - GRAYLOG_HTTP_PUBLISH_URI=http://192.168.1.28:9000/
      - GRAYLOG_TRANSPORT_EMAIL_PROTOCOL=smtp
      - GRAYLOG_HTTP_ENABLE_CORS=true
      - GRAYLOG_TRANSPORT_EMAIL_WEB_INTERFACE_URL=http://192.168.1.28:9000/
      - GRAYLOG_TRANSPORT_EMAIL_HOSTNAME=192.168.1.28
      - GRAYLOG_TRANSPORT_EMAIL_ENABLED=true
      - GRAYLOG_TRANSPORT_EMAIL_PORT=25
      - GRAYLOG_TRANSPORT_EMAIL_USE_AUTH=false
      - GRAYLOG_TRANSPORT_EMAIL_USE_TLS=false
      - GRAYLOG_TRANSPORT_EMAIL_USE_SSL=false
      - GRAYLOG_TRANSPORT_FROM_EMAIL=root@localhost
      - GRAYLOG_TRANSPORT_SUBJECT_PREFIX=[graylog]
      - GRAYLOG_REPORT_DISABLE_SANDBOX=true
I think your issue might be in this part of you configuration, not 100% sure.
What Im not seeing is your network???
Example:
version: '2'
services:
  mongodb:
    image: mongo:4
    network_mode: bridge
   # DB in share for persistence
    volumes:
      - mongo_data:/data/db
   # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
I used network_mode: bridge setting works great.
And last
    links:
      - mongodb:mongo
      - elasticsearch
    depends_on:
      - mongodb
      - elasticsearch
Hope that helps
Thanks for your reply - but i see you are not using https for docker. When i disable https then it works
Here the full error messag
2023-04-13 05:13:14,974 ERROR: org.graylog2.bootstrap.ServerBootstrap - Graylog startup failed. Exiting. Exception was:
        Caused by: java.security.GeneralSecurityException: org.bouncycastle.pkcs.PKCSException: unable to read encrypted data: Error finalising cipher
                at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:88) ~[graylog.jar:?]
                at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:360) ~[graylog.jar:?]
                at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:178) ~[graylog.jar:?]
                at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:159) ~[graylog.jar:?]
                at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
                at com.google.common.util.concurrent.Callables$4.run(Callables.java:121) ~[graylog.jar:?]
                at java.lang.Thread.run(Unknown Source) ~[?:?]
        Caused by: org.bouncycastle.pkcs.PKCSException: unable to read encrypted data: Error finalising cipher
                at org.bouncycastle.pkcs.PKCS8EncryptedPrivateKeyInfo.decryptPrivateKeyInfo(Unknown Source) ~[graylog.jar:?]
                at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:68) ~[graylog.jar:?]
                at org.graylog2.shared.security.tls.PemKeyStore.doBuildKeyStore(PemKeyStore.java:99) ~[graylog.jar:?]
                at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:85) ~[graylog.jar:?]
        Caused by: org.bouncycastle.crypto.io.InvalidCipherTextIOException: Error finalising cipher
                at org.bouncycastle.jcajce.io.CipherInputStream.finaliseCipher(Unknown Source) ~[graylog.jar:?]
                at org.bouncycastle.jcajce.io.CipherInputStream.nextChunk(Unknown Source) ~[graylog.jar:?]
                at org.bouncycastle.jcajce.io.CipherInputStream.read(Unknown Source) ~[graylog.jar:?]
                at org.bouncycastle.util.io.Streams.pipeAll(Streams.java:114) ~[graylog.jar:?]
                at org.bouncycastle.util.io.Streams.readAll(Streams.java:41) ~[graylog.jar:?]
        Caused by: javax.crypto.BadPaddingException: pad block corrupted
                at org.bouncycastle.jcajce.provider.symmetric.util.BaseBlockCipher$BufferedGenericBlockCipher.doFinal(Unknown Source) ~[graylog.jar:?]
                at org.bouncycastle.jcajce.provider.symmetric.util.BaseBlockCipher.engineDoFinal(Unknown Source) ~[graylog.jar:?]
                at javax.crypto.Cipher.doFinal(Unknown Source) ~[?:?]
I think something with the pem-File is wrong or missconfigured
Hey @MyKeySoftMK
Yeah something does look incorrect, either with the configurations for HTTP/TLS or the certs.
I have configured my Graylog Docker config file (i.e.graylog.conf) to have these settings configured.
http_publish_uri = https://graylog.domain.com:9000/
## I used the directory where i create the certs and chown graylog:graylog -R.
http_tls_key_file = /path/to/certs/graylog-key.pem
http_tls_cert_file = /path/to/certs/graylog-certificate.pem
You can also use the environment variables in your Docker-Compose file if you wish.
