I want to send IIS logs from Windows10 to Ubuntu 20.04 graylog server.
I have install graylog on ubuntu and it works fine. I have tried to get Windows10 event logs and successfully got it .But I cannot get IIS logs from Windows10 to Graylog server (Ubuntu 20.04).
Here is my configuration code
I NEED A CORRECT CONFIGURATION FILE
If so, then use the “telnet” command to check if the Port is listening in your IIS server. telnet <YourGraylogIP> 12201
If you still have problems, create a new input (Syslog UDP) with another PORT and try again
I have tried both of them .I have already got connnected and network is up as you can see in the pic.I turned off windows firewall in case it may be block the traffic but still do not get logs in search tab. Is there anything wrong with my elasticsearch ?
If the Input is running and you are not getting messages 90% is from the settings on NXLOG
Can you check the output log?
Maybe you should check activate this and very if theres any information
Output logs seem good.It just say connected succesfully .I have shared photos that you can see there is no error . Can anyone share another config file so that I can implement it to my config ?
Also, why are you using a GELF-TCP Input and your Nxlog is configured for UDP?
Might want to try to use a GELF UDP input and see if that works.
EDIT: I think your on the right path, you need to match up your Log shipper configuration with you Graylog Input. If I’m seeing this correct on your nxlog config file your input section is using json format? If so take a look here
You may need to change your Graylog Input to match that format. Maybe something like Raw/PlainText then adjust you nxlog Output section to match that input. I also did a quick search speaking of Nxlog configuration there might be something in these post will help you out.
Thank you guys I finally solved my problem.The problem was json format.I convert logs to json format but I did not exec it .So adding * Exec to_json(); * to output I successfully got logs. It does not matter udp or tcp but I used tcp as graylog input
