If I export log, incorrect timestamp issue
Hi!!!
I have an issue. Please, can you help me?
My issue is that if I export the log with CSV file, the timestamp is incorrect. Why is that?
I have installed Graylog 4.0 on Ubuntu OS.
Timezone
Time Configuration
Probably it’s not incorrect, but only in UTC time, it’s a format used to store timestamps in ES DB.
Thanks for your suggestion.
