I want to integrate other system with GrayLog
Greetings,
I want to integrate some another performance monitoring system with GrayLog. Exactly requirement is Gray log should push the processed logs after some each random interval to some another system.
Basically we well use these process logs from Graylog into another system.
So my questions are,
1)Is there any build in way where we can push the processed logs from GrayLog server itself to other systems.
2)As this looks something out of the primary object of Graylog product ,I want to know if the point 1 is possible then is it recommended to do so or will it have any impact on existing Graylog setup.
Thanks in advance.
