I finally figured it out how to write the RT_FLOW_SESSION_DENY Syslog Grok pattern for the Juniper SRX
source-address=“%{IP:src_ip}” source-port=“%{INT:src_port}” destination-address=“%{IP:dst_ip}” destination-port=“%{INT:dst_port}” connection-tag=“%{INT:connection_tag}” service-name=“%{DATA:service_name}” nat-source-address=“%{IP:nat-source-address}” nat-source-port=“%{INT:nat-source-port}” nat-destination-address=“%{IP:nat-destination-address}” nat-destination-port=“%{INT:nat-destination-port}” nat-connection-tag=“%{INT:nat-connection-tag}” src-nat-rule-type=“%{DATA:src-nat-rule-type}” src-nat-rule-name=“%{DATA:src-nat-rule-name}” dst-nat-rule-type=“%{DATA:dst-nat-rule-type}” dst-nat-rule-name=“%{DATA:dst-nat-rule-name}” protocol-id=“%{INT:protocol-id}” policy-name=“%{DATA:policy-name}” source-zone-name=“%{DATA:source-zone-name}” destination-zone-name=“%{DATA:destination-zone-name}” session-id=“%{INT:session-id}” username=“%{DATA:username}” roles=“%{DATA:roles}” packet-incoming-interface=“%{DATA:incoming-interface}” application=“%{DATA:application}” nested-application=“%{DATA:nested-application}” encrypted=“%{DATA:encrypted}” application-category=“%{DATA:application-category}” application-sub-category=“%{DATA:application-sub-category}” application-risk=“%{DATA:application-risk}” application-characteristics=“%{DATA:application-characteristics}” src-vrf-grp=“%{DATA:src_vr_grp}” dst-vrf-grp=“%{DATA:dst-vrf-grp}” tunnel-inspection=“%{DATA:tunnel-inspection}” tunnel-inspection-policy-set=“%{DATA:tunnel-inspection-policy-set}”
Hey @jrecho
Holy cow that huge :laughing:
