Hi, this is my first time I am using graylog. So please don’t kill if my question is too basic.
I have to connect an existing java 8 application with maven and running in Wilfly with graylog.
The first thing I tried was run a test graylog project.
This project run a docker graylog.
This is the docker-compose.yaml file:
version: '2'
services:
mongodb:
image: mongo:3
volumes:
- mongo_data:/data/db
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.x/docker.html
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.2
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
image: graylog/graylog:3.1
volumes:
environment:
- GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data, see
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
The test project is a gradle project using this configuration:
plugins {
id “java”
id “org.springframework.boot” version “2.4.3”
id “io.spring.dependency-management” version “1.0.9.RELEASE”
group = ‘com.graylog’
version = ‘1.0.0-SNAPSHOT’
repositories {
mavenCentral()
configurations {
all*.exclude module : “spring-boot-starter-logging”
all*.exclude module : “log4j”
dependencies {
implementation “org.springframework.boot:spring-boot-starter-web”
implementation “org.apache.logging.log4j:log4j-api:2.14.1”
implementation “org.apache.logging.log4j:log4j-core:2.14.1”
implementation “org.slf4j:slf4j-api:1.7.9”
implementation “org.slf4j:slf4j-simple:1.7.9”
implementation “biz.paluch.logging:logstash-gelf:1.14.1”
// implementation “de.siegmar:logback-gelf:3.0.0”
The class:
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
@RestController
public class LoggingController {
private final static Logger logger = LoggerFactory.getLogger(LoggingController.class);
@GetMapping("/add")
public String index() {
logger.trace("A TRACE Message");
logger.debug("A DEBUG Message");
logger.info("An INFO Message");
logger.warn("A WARN Message");
logger.error("An ERROR Message");
return "Howdy! Check out the Logs to see the output...";
Run and save in the graylog, so it works right.
In the project that I inherit they are using org.slf4j and I added logback-gelf dependencies. It now
is like this:
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
</dependency>
<dependency>
<artifactId>slf4j-simple</artifactId>
</dependency>
<dependency>
<groupId>de.siegmar</groupId>
<artifactId>logback-gelf</artifactId>
<version>3.0.0</version>
</dependency>
The logback.xml is the same in the test project as in real project:
<configuration debug="true">
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
<encoder>
<pattern>%green(%date) %highlight(%-5level) %yellow([%-4relative]) %magenta([%thread]) %cyan(%logger{10}) %gray([%file:%line]) %blue(: %msg%n)</pattern>
<charset>UTF-8</charset>
</encoder>
</appender>
<appender name="GELF" class="de.siegmar.logbackgelf.GelfUdpAppender">
<graylogHost>localhost</graylogHost>
<graylogPort>12201</graylogPort>
</appender>
<!-- Use AsyncAppender to prevent slowdowns -->
<appender name="ASYNC GELF" class="ch.qos.logback.classic.AsyncAppender">
<appender-ref ref="GELF" />
</appender>
<root level="debug">
<appender-ref ref="STDOUT" />
<appender-ref ref="ASYNC GELF" />
</root>
</configuration>
And the classes that log are like this:
@ApplicationScoped
public class MyClassImpl implements MyClass {
private static final Logger logger = LoggerFactory.getLogger(MyClassImpl.class);
@Override
public Response categories() {
logger.info("getting categories in MyClassImpl");
return Response.ok().entity(MyDAO.getCategories()).build();
I run the real project and I see logs in console but not in the graylog. Also there is no error in the console.
I am thinking that I am missing in my configuration or doing wrong in my configuration but I can’t figure out what is because I duplicated dependencies and logback.xml file in 2 projects.
Any help is welcome.
Thanks.
Mariano
