I don’t see any more information. Is the debug SSL info put somewhere else?
> 2021-03-25T17:26:51.485-04:00 INFO [CmdLineTool] Loaded plugin: AWS plugins 3.2.6 [org.graylog.aws.AWSPlugin]
> 2021-03-25T17:26:51.487-04:00 INFO [CmdLineTool] Loaded plugin: Collector 3.2.6 [org.graylog.plugins.collector.CollectorPlugin]
> 2021-03-25T17:26:51.487-04:00 INFO [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 3.2.6 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
> 2021-03-25T17:26:51.737-04:00 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/etc/ssl/certs/graylog/graylog-key.jks -Djavax.net.debug=ssl,keymanager -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
> 2021-03-25T17:26:51.892-04:00 INFO [Version] HV000001: Hibernate Validator null
> 2021-03-25T17:26:54.000-04:00 INFO [InputBufferImpl] Message journal is enabled.
> 2021-03-25T17:26:54.016-04:00 INFO [NodeId] Node ID: 3e272ba8-ed29-40c1-b7db-9a2850d5b65e
> 2021-03-25T17:26:54.182-04:00 INFO [LogManager] Loading logs.
> 2021-03-25T17:26:54.235-04:00 INFO [LogManager] Logs loading complete.
> 2021-03-25T17:26:54.238-04:00 INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
> 2021-03-25T17:26:54.256-04:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
> 2021-03-25T17:26:54.292-04:00 INFO [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
> 2021-03-25T17:26:54.312-04:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:186}] to localhost:27017
> 2021-03-25T17:26:54.316-04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 4, 4]}, minWireVersion=0, maxWireVersion=9, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=2348299}
> 2021-03-25T17:26:54.327-04:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:187}] to localhost:27017
> 2021-03-25T17:26:54.459-04:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
> 2021-03-25T17:26:54.720-04:00 INFO [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
> 2021-03-25T17:26:54.721-04:00 INFO [JestClientFactory] Using multi thread/connection supporting pooling connection manager
> 2021-03-25T17:26:54.773-04:00 INFO [JestClientFactory] Using custom ObjectMapper instance
> 2021-03-25T17:26:54.773-04:00 INFO [JestClientFactory] Node Discovery disabled...
> 2021-03-25T17:26:54.773-04:00 INFO [JestClientFactory] Idle connection reaping disabled...
> 2021-03-25T17:26:55.194-04:00 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
> 2021-03-25T17:26:55.411-04:00 INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
> 2021-03-25T17:26:55.449-04:00 INFO [connection] Opened connection [connectionId{localValue:3, serverValue:188}] to localhost:27017
> 2021-03-25T17:26:56.007-04:00 INFO [ServerBootstrap] Graylog server 3.2.6+e255fcc starting up
> 2021-03-25T17:26:56.007-04:00 INFO [ServerBootstrap] JRE: Debian 11.0.9.1 on Linux 4.19.0-14-amd64
> 2021-03-25T17:26:56.007-04:00 INFO [ServerBootstrap] Deployment: deb
> 2021-03-25T17:26:56.008-04:00 INFO [ServerBootstrap] OS: Debian GNU/Linux 10 (buster) (debian)
> 2021-03-25T17:26:56.008-04:00 INFO [ServerBootstrap] Arch: amd64
> 2021-03-25T17:26:56.037-04:00 INFO [PeriodicalsService] Starting 30 periodicals ...
> 2021-03-25T17:26:56.037-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
> 2021-03-25T17:26:56.047-04:00 INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
> 2021-03-25T17:26:56.049-04:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
> 2021-03-25T17:26:56.049-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
> 2021-03-25T17:26:56.049-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
> 2021-03-25T17:26:56.057-04:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
> 2021-03-25T17:26:56.057-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
> 2021-03-25T17:26:56.061-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
> 2021-03-25T17:26:56.062-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
> 2021-03-25T17:26:56.069-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
> 2021-03-25T17:26:56.071-04:00 INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
> 2021-03-25T17:26:56.072-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
> 2021-03-25T17:26:56.080-04:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.VersionCheckThread] periodical. Not configured to run on this node.
> 2021-03-25T17:26:56.080-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
> 2021-03-25T17:26:56.081-04:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
> 2021-03-25T17:26:56.081-04:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
> 2021-03-25T17:26:56.086-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
> 2021-03-25T17:26:56.086-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
> 2021-03-25T17:26:56.088-04:00 INFO [connection] Opened connection [connectionId{localValue:4, serverValue:189}] to localhost:27017
> 2021-03-25T17:26:56.091-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
> 2021-03-25T17:26:56.098-04:00 INFO [connection] Opened connection [connectionId{localValue:5, serverValue:190}] to localhost:27017
> 2021-03-25T17:26:56.098-04:00 INFO [connection] Opened connection [connectionId{localValue:7, serverValue:192}] to localhost:27017
> 2021-03-25T17:26:56.101-04:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
> 2021-03-25T17:26:56.101-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
> 2021-03-25T17:26:56.106-04:00 INFO [connection] Opened connection [connectionId{localValue:6, serverValue:191}] to localhost:27017
> 2021-03-25T17:26:56.107-04:00 INFO [connection] Opened connection [connectionId{localValue:8, serverValue:193}] to localhost:27017
> 2021-03-25T17:26:56.119-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
> 2021-03-25T17:26:56.141-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
> 2021-03-25T17:26:56.153-04:00 INFO [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
> 2021-03-25T17:26:56.158-04:00 INFO [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
> 2021-03-25T17:26:56.159-04:00 INFO [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
> 2021-03-25T17:26:56.159-04:00 INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
> 2021-03-25T17:26:56.160-04:00 INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
> 2021-03-25T17:26:56.160-04:00 INFO [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
> 2021-03-25T17:26:56.161-04:00 INFO [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
> 2021-03-25T17:26:56.161-04:00 INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
> 2021-03-25T17:26:56.249-04:00 INFO [LookupTableService] Data Adapter geoip/6032ac73d48b0d27ac998574 [@49f42058] STARTING
> 2021-03-25T17:26:56.310-04:00 INFO [LookupDataAdapterRefreshService] Adding job for <geoip/6032ac73d48b0d27ac998574/@49f42058> [interval=60000ms]
> 2021-03-25T17:26:56.309-04:00 INFO [LookupTableService] Data Adapter geoip/6032ac73d48b0d27ac998574 [@49f42058] RUNNING
> 2021-03-25T17:26:56.393-04:00 INFO [LookupTableService] Cache geoip/6032ac98d48b0d27ac99859e [@507e9ddb] STARTING
> 2021-03-25T17:26:56.406-04:00 INFO [LookupTableService] Cache geoip/6032ac98d48b0d27ac99859e [@507e9ddb] RUNNING
> 2021-03-25T17:26:56.414-04:00 INFO [LookupTableService] Starting lookup table geoip/6032acafd48b0d27ac9985ba [@20d092b7] using cache geoip/6032ac98d48b0d27ac99859e [@507e9ddb], data adapter geoip/6032ac73d48b0d27ac998574 [@49f42058]
> 2021-03-25T17:26:56.579-04:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Failed [LB:DEAD]
> 2021-03-25T17:26:56.581-04:00 ERROR [InputSetupService] Not starting any inputs because lifecycle is: Failed [LB:DEAD]
> 2021-03-25T17:26:56.589-04:00 INFO [GracefulShutdownService] Running graceful shutdown for <1> shutdown hooks
> 2021-03-25T17:26:56.590-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread].
> 2021-03-25T17:26:56.590-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] complete, took <0ms>.
> 2021-03-25T17:26:56.590-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ClusterHealthCheckThread].
> 2021-03-25T17:26:56.591-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ClusterHealthCheckThread] complete, took <0ms>.
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexerClusterCheckerThread].
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexerClusterCheckerThread] complete, took <0ms>.
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRetentionThread].
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRetentionThread] complete, took <0ms>.
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRotationThread].
> 2021-03-25T17:26:56.592-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRotationThread] complete, took <0ms>.
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.ThrottleStateUpdaterThread].
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.ThrottleStateUpdaterThread] complete, took <0ms>.
> 2021-03-25T17:26:56.593-04:00 INFO [GracefulShutdownService] Initiate shutdown for <JobWorkerPool>
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventPeriodical] complete, took <0ms>.
> 2021-03-25T17:26:56.593-04:00 INFO [GracefulShutdownService] Finished shutdown for <JobWorkerPool>, took 0 ms
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.events.ClusterEventCleanupPeriodical] complete, took <0ms>.
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical].
> 2021-03-25T17:26:56.593-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.IndexRangesCleanupPeriodical] complete, took <0ms>.
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.periodical.TrafficCounterCalculator].
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.periodical.TrafficCounterCalculator] complete, took <0ms>.
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical].
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] complete, took <0ms>.
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp].
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] complete, took <0ms>.
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread].
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] complete, took <0ms>.
> 2021-03-25T17:26:56.594-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads].
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] complete, took <0ms>.
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob].
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.views.search.db.SearchesCleanUpJob] complete, took <0ms>.
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp].
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.events.periodicals.EventNotificationStatusCleanUp] complete, took <0ms>.
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutting down periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread].
> 2021-03-25T17:26:56.595-04:00 INFO [PeriodicalsService] Shutdown of periodical [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] complete, took <0ms>.
> 2021-03-25T17:26:56.602-04:00 INFO [JournalReader] Stopping.
> 2021-03-25T17:26:56.606-04:00 INFO [LogManager] Shutting down.
> 2021-03-25T17:26:56.622-04:00 INFO [LookupTableService] Cache geoip/6032ac98d48b0d27ac99859e [@507e9ddb] STOPPING, was RUNNING
> 2021-03-25T17:26:56.626-04:00 INFO [LookupTableService] Data Adapter geoip/6032ac73d48b0d27ac998574 [@49f42058] STOPPING, was RUNNING
> 2021-03-25T17:26:56.640-04:00 INFO [LookupTableService] Cache geoip/6032ac98d48b0d27ac99859e [@507e9ddb] TERMINATED, was STOPPING
> 2021-03-25T17:26:56.640-04:00 INFO [LookupTableService] Data Adapter geoip/6032ac73d48b0d27ac998574 [@49f42058] TERMINATED, was STOPPING
> 2021-03-25T17:26:56.644-04:00 INFO [LookupDataAdapterRefreshService] Stopping 1 jobs
> 2021-03-25T17:26:56.644-04:00 INFO [Buffers] Waiting until all buffers are empty.
> 2021-03-25T17:26:56.652-04:00 INFO [Buffers] All buffers are empty. Continuing.
> 2021-03-25T17:26:56.653-04:00 INFO [OutputSetupService] Stopping output org.graylog2.outputs.BlockingBatchedESOutput
> 2021-03-25T17:26:56.658-04:00 INFO [LogManager] Shutdown complete.
> 2021-03-25T17:27:26.637-04:00 ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], GracefulShutdownService [TERMINATED], PeriodicalsService [TERMINATED], UrlWhitelistService [TERMINATED], JournalReader [TERMINATED], StreamCacheService [TERMINATED], OutputSetupService [TERMINATED], EtagService [TERMINATED], LookupTableService [TERMINATED], ConfigurationEtagService [TERMINATED], BufferSynchronizerService [TERMINATED], KafkaJournal [TERMINATED]], FAILED=[JerseyService [FAILED]]}
> 2021-03-25T17:27:26.638-04:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
> java.lang.IllegalStateException: Expected to be healthy after starting. The following services are not running: {FAILED=[JerseyService [FAILED]]}
> at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
> at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
> at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
> at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:161) ~[graylog.jar:?]
> at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) ~[graylog.jar:?]
> at org.graylog2.bootstrap.Main.main(Main.java:50) ~[graylog.jar:?]
> Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
> Caused by: java.security.NoSuchAlgorithmException: 1.2.840.113549.1.5.13 SecretKeyFactory not available
> at javax.crypto.SecretKeyFactory.<init>(SecretKeyFactory.java:122) ~[?:?]
> at javax.crypto.SecretKeyFactory.getInstance(SecretKeyFactory.java:168) ~[?:?]
> at org.graylog2.shared.security.tls.PemKeyStore.generateKeySpec(PemKeyStore.java:70) ~[graylog.jar:?]
> at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:98) ~[graylog.jar:?]
> at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:347) ~[graylog.jar:?]
> at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:172) ~[graylog.jar:?]
> at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:146) ~[graylog.jar:?]
> at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
> at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
> at java.lang.Thread.run(Thread.java:834) ~[?:?]
> 2021-03-25T17:27:26.646-04:00 INFO [Server] SIGNAL received. Shutting down.
> 2021-03-25T17:27:26.654-04:00 INFO [GracefulShutdown] Graceful shutdown initiated.
> 2021-03-25T17:27:26.655-04:00 INFO [GracefulShutdown] Node status: [Halting [LB:DEAD]]. Waiting <3sec> for possible load balancers to recognize state change.
> 2021-03-25T17:27:30.658-04:00 INFO [GracefulShutdown] Goodbye.
