"In order for the JVM to pick up the new trust store, it has to be started with the JVM parameter -Djavax.net.ssl.trustStore=/path/to/cacerts.jks. If you’ve been using another password to encrypt the JVM trust store than the default changeit, you additionally have to set the JVM parameter -Djavax.net.ssl.trustStorePassword=secret.
Most start and init scripts for Graylog provide a JAVA_OPTS variable which can be used to pass the javax.net.ssl.trustStore and (optionally) javax.net.ssl.trustStorePassword system properties."
How do I get the start the graylog JVM with the trustStore parameter?
2017-05-02T22:40:53.625-04:00 WARN [ProxiedResource] Unable to call https://10.16.1.90:9000/api/system/metrics/multiple on node <b6c85752-7456-4248-a5f5-2693c1fd94f7>
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1959) ~[?:1.8.0_131]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:302) ~[?:1.8.0_131]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:296) ~[?:1.8.0_131]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1514) ~[?:1.8.0_131]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) ~[?:1.8.0_131]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:1.8.0_131]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:961) ~[?:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072) ~[?:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:1.8.0_131]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:1.8.0_131]
at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:242) ~[graylog.jar:?]
at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:200) ~[graylog.jar:?]
at okhttp3.internal.connection.RealConnection.buildConnection(RealConnection.java:174) ~[graylog.jar:?]
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:114) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:196) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:132) ~[graylog.jar:?]
at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:101) ~[graylog.jar:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:179) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:63) ~[graylog.jar:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:174) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$null$0(ProxiedResource.java:76) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:387) ~[?:1.8.0_131]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292) ~[?:1.8.0_131]
at sun.security.validator.Validator.validate(Validator.java:260) ~[?:1.8.0_131]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:1.8.0_131]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:1.8.0_131]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:1.8.0_131]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1496) ~[?:1.8.0_131]
... 36 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_131]
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_131]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_131]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:382) ~[?:1.8.0_131]
... 36 more
2017-05-02T22:40:57.096-04:00 WARN [ProxiedResource] Unable to call https://10.16.1.90:9000/api/system/metrics/multiple on node <b6c85752-7456-4248-a5f5-2693c1fd94f7>
... 36 more
... 36 more
if your certificate is in dir -where you want- you can use the following commands (check parameters and substitute your own file names)
cp -a /usr/lib/jvm/jre-1.8.0-openjdk/lib/security/cacerts /-where you want-/cacerts.jks
keytool -importcert -keystore /-where you want-/cacerts.jks -storepass changeit -alias graylog-CA-signed -file /-where you want-/graylog-cert.pem
Then set the Java VM to use your modified keystore file with the parameter you know already.
This is where I had the problem… I did everything else already. This part of the documentation is not clear. All it says is… “Most start and init scripts for Graylog provide a JAVA_OPTS variable which can be used to pass the javax.net.ssl.trustStore and (optionally) javax.net.ssl.trustStorePassword system properties.” but how do I get theDjavax.net.ssl.trustStore variable into the JAVA_OPTS variable?
Well if anyone else reads this, I did get it to work doing the below…
For Centos 7 go to the jvm settings file location which is /etc/sysconfig
open the graylog-server file and edit the file like below…
(# Default Java options for heap and garbage collection.
GRAYLOG_SERVER_JAVA_OPTS="-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=[add path to cert (*.jks) here]"
