Graylog2 Using https
Hello All,
I am having a problem with https on graylog2.2.3, Currently using CentOS-7.3 all in one graylog2 server. This is a Virtual machine with 8 cores, 10 GB of ram and 1 Tb storage.
I created an Input for Localhost and tested to received messages, completed. No problems.
I attempted to use the following:
http://docs.graylog.org/en/2.2/pages/configuration/https.html
Unfortunately, toward the end of the page I was having problems with JVM to pick up the new trust store. So, I attempted to follow these instructions as shown below;
This work flawlessly, logged in with https://ipaddress:9000/gettingstarted
Some problems were noticed, for example: My Input created for Localhost now shows [0 Running] and I cannot start them (i.e. it errors out “unable to start input”), but I’m receiving messages from localhost on that Input, Kind of weird. The Second Problem noticed is when I navigate to System > Logging see the following;
ff45be84 / test-graylog.enseva-labs.net Has written a total of n/a internal log messages. If I Click on the link “ff45be84 / test-graylog.enseva-labs.net” I receive the following error:
We had trouble fetching some data required to build this page, so here is a picture instead. Error: cannot GET https://ipaddres:9000/api/cluster/ff45be84-46ee-47b5-a46e-5a3fef085c73/jvm (500)
Check your Graylog logs for more information.
Graylog files continue to show the following error;
2017-10-17T21:02:34.077-05:00 WARN [ProxiedResource] Unable to call https://ipaddress:9000/api/system/metrics/multiple on node javax.net.ssl.SSLPeerUnverifiedException: Hostname ipaddress not verified: certificate: sha256/8gOPCINQyuUol2SFmo0WXrP+TBYWeHxgqtp9f9ENct0= DN: CN=Unknown, OU=Unknown, O=Unknown, L=Unknown, ST=Unknown, C=Unknown
I’ve been googling for 5 days trying to figure out how to solve this problem. Any help or direction to solve this problem would be appreciated.
Thank you in advance
I fixed my problem. I was trying to use an IP Address instead of FQDN.
I had to do some reconfiguring.
  1. Configure my CentOS 7 Virtual Machine /hosts and /hostname file to a FQDN
  2. Made a PTR record on my DNS Server for my Graylog Server.
  3. Make Certs, I filled out Organizational Unit as FQDN.
  4. Reconfigured my Graylog.conf file as follow;
rest_listen_uri = http://FQDN:9000/api/
web_listen_uri = http://FQDN:9000/
I restarted my Graylog server, everything works as expected.
I should of waited before posting.
Hi @gsmith
I am trying the same setup in one of my Google Cloud Platform and I am getting the same exception in logs when I am trying to navigate some other page in Graylog. I followed this link to setup the SSL
2017-11-02T06:42:22.847Z WARN  [ProxiedResource] Unable to call https://localhost:9000/api/system/metrics/multiple on node <317427ae-de50-4ae6-a100-e9137244d6d8>
javax.net.ssl.SSLPeerUnverifiedException: Hostname: XXXXX not verified:
    certificate: sha256/Q+bQmmOWmFLeDy1Rs80WMVC3AlQI4ihpj+2Y+IL4fAI=
    DN: CN=manik basha, OU=39.164.202.35.bc.googleusercontent.com., O=39.164.202.35.bc.googleusercontent.com., L=mumbai, ST=maharastra, C=IN
    subjectAltNames: []
        at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:290) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:251) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:151) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:192) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:121) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:100) ~[graylog.jar:?]
        at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[graylog.jar:?]
        at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[graylog.jar:?]
        at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185) ~[graylog.jar:?]
        at okhttp3.RealCall.execute(RealCall.java:69) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:76) ~[graylog.jar:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_144]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_144]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_144]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_144]
I have uploaded my Graylog conf file please kindly check and correct me If I am doing anything wrong in the setup.
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = IxtU2Wjsr7ml6CAICvRzNvkerAXTbvH5dVFmUmCjW2rU0aEnAv7LLwvBVbx3wBN
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = e3c652f0ba0b4801205814f8b6bc47770bb89b22cdeb4e951
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://10.128.0.7:9000/api/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
rest_transport_uri = https://35.202.164.39:9000/api/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
rest_tls_cert_file = /etc/graylog/graylog-certificate.pem
# The PKCS#8 private key file in PEM format to use for securing the REST API.
rest_tls_key_file = /etc/graylog/graylog-key.pem
# The password to unlock the private key used for securing the REST API.
rest_tls_key_password = secret
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://10.128.0.7:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = true
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
web_tls_cert_file =  /etc/graylog/graylog-certificate.pem
# The PKCS#8 private key file in PEM format to use for securing the web interface.
web_tls_key_file =  /etc/graylog/graylog-key.pem
# The password to unlock the private key used for securing the web interface.
web_tls_key_password = secret
#web_max_header_size = 8192
#web_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# requires authentication.
ielasticsearch_hosts = http://35.202.164.39:9200
#http://user:password@node2:19200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
My Google cloud VM has two IP’s internal & external… I have configured internal IP
rest_listen_uri = http://X.XXX.XX.X:9000/api/
web_listen_uri = http://XX.XXX.XX.X:9000/
Configured External IP in rest_transport_uri = https://X.XXX.XX.X:9000/api/
Please correct me if I am doing anything wrong and if possible can you please share your graylog.conf for reference.
Thanks,
Ganeshbabu R
@Ganeshbabu
This is what help solve my issues as shown below;
I’m running CentOS 7.3, All in one Graylog Server.
This site is how I setup my Test environment. I used the same Version of elasticsearch and MongoDb
Then I used this to make my Certs.
Just an FYI, I made a backup of my JVM trust store (cacerts) prior to any configurations.
  1. I had to make sure my graylog server has a PTR record in the Domain DNS server. You should be able to ping your Graylog FQDN
  2. My rest_listen_uri and web_listen_uri as shown below (i.e. I used FQDN instead of IP Address);
    rest_listen_uri = http://test-graylog.net:9000/api/
    web_listen_uri = http://test-graylog.net:9000/api/
Side NOTE:
I set my Graylog server root_timezone = America/Chicago
Is there supposed to be an “i” in-front of ielasticsearch_hosts ?
Hope that helps…
@gsmith
No while copy paste I made a mistake.
I am using Google cloud VM and I mentioned it has two IP’s (Internal & external IP address)
Since Google cloud VM “FDQN” or hostname are not accessible in the web interface and through external IP address only I am able to access it.
I tried by using the Public IP address but not able to do it and however I am getting the error in logs,
2017-11-07T12:20:56.321Z WARN  [ProxiedResource] Unable to call https://35.192.107.138:9000/api/system/metrics/multiple on node <12bd94c6-bd85-4640-a0ea-22d439d08c7b>
javax.net.ssl.SSLPeerUnverifiedException: Hostname 35.192.107.138 not verified:
    certificate: sha256/dCeFF9ZLi0kLikrKOct1YCj5BG1K3J3CRzIaZxcR7yo=
    DN: CN=35.192.107.138, OU=35.192.107.138, O=35.192.107.138, L=mumbai, ST=maharastra, C=IN
    subjectAltNames: []
My Google cloud console
Did you get any chance to try it in Google cloud Instance?
Regards,
Ganeshbabu R
@Ganeshbabu
Sorry I don’t use Google Cloud. I just started using Graylog2 this past year so I’m not to familiar with some configurations.
Also I only work within our private network. I do know using a FQDN help out in most cases.
-Greg
Yes @gsmith
For my private network Graylog is working fine with HTTPS and I am trying to do the same HTTPS setup in public network but the certificate and key pem files generated using this documentation is not working and its throwing hostname is not verified.
Thanks,
Ganeshbabu R
did the certificate include the private and the public hostname and ip address?
@jan
Yes I include the hostname & IP address while generating the certificate and I followed this script
Below are my google cloud VM details,
Private IP : - 10.128.0.9
Public IP :- 104.198.57.170
Hostname : - graylogssl
Below is the commands I used to generate graylog-certificate.pem & graylog-key.pem files and I included all the steps, Please kindly check once and correct me where I am doing wrong. I have been struggling this setup in Google VM for long time.
Generating certificate & key using script
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# bash create_ssl_certs.sh -h graylogssl -i 10.128.0.9
This script will generate a SSL certificate with the following settings:
CN Hostname = graylogssl
subjectAltName = DNS:graylogssl,IP:10.128.0.9
the following files are written to the current directory:
  - graylogssl.pkcs5-plain.key.pem
  - graylogssl.pkcs8-plain.key.pem
  - graylogssl.pkcs8-encrypted.key.pem
    with the password: secret
Generating keystore.jks using keytool
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# keytool -genkey -alias 10.128.0.9 -keyalg RSA -validity 365 -keystore keystore.jks
Enter keystore password:
Re-enter new password:
What is your first and last name?
  [Unknown]:  graylogssl
What is the name of your organizational unit?
  [Unknown]:  server
What is the name of your organization?
  [Unknown]:  graylog
What is the name of your City or Locality?
  [Unknown]:  mumbai
What is the name of your State or Province?
  [Unknown]:  maharastra
What is the two-letter country code for this unit?
  [Unknown]:  IN
Is CN=graylogssl, OU=server, O=graylog, L=mumbai, ST=maharastra, C=IN correct?
  [no]:  yes
Enter key password for <10.128.0.9>
        (RETURN if same as keystore password):
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using "keytool -importkeystore -srckeystore keystore.jks -destkeystore keystore.jks -deststoretype pkcs12".
Check the certificate in keystore.jks
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# keytool -list -v -keystore keystore.jks -alias 10.128.0.9
Alias name: 10.128.0.9
Creation date: Nov 15, 2017
Entry type: PrivateKeyEntry
Certificate chain length: 1
Certificate[1]:
Owner: CN=graylogssl, OU=server, O=graylog, L=mumbai, ST=maharastra, C=IN
Issuer: CN=graylogssl, OU=server, O=graylog, L=mumbai, ST=maharastra, C=IN
Serial number: 15318758
Valid from: Wed Nov 15 16:59:24 UTC 2017 until: Thu Nov 15 16:59:24 UTC 2018
Certificate fingerprints:
         MD5:  0B:F9:28:13:44:27:AB:4B:F1:AE:3B:4F:73:E8:A4:60
         SHA1: 99:D2:A8:BC:13:DB:F4:DE:ED:CE:9C:63:A0:B4:A3:F5:28:6D:7E:E4
         SHA256: CA:49:F8:BC:D3:F6:13:C2:73:27:B4:5E:7A:10:F3:4B:E0:20:24:AC:17:F3:EF:0D:48:1E:0B:0D:93:1A:CF:1D
Signature algorithm name: SHA256withRSA
Subject Public Key Algorithm: 2048-bit RSA key
Version: 3
Extensions:
#1: ObjectId: 2.5.29.14 Criticality=false
SubjectKeyIdentifier [
KeyIdentifier [
0000: DE BC 99 DB D2 F4 05 54   70 FC CC CD D1 27 2B D4  .......Tp....'+.
0010: 35 E1 BA 86                                        5...
Warning:
jks format converted to pkcs12 format
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# keytool -importkeystore -srckeystore keystore.jks -destkeystore keystore.p12 -deststoretype PKCS12
Importing keystore keystore.jks to keystore.p12...
Enter destination keystore password:
Enter source keystore password:
Entry for alias 10.128.0.9 successfully imported.
Import command completed:  1 entries successfully imported, 0 entries failed or cancelled
openssl can export the x509 certificate to pem encoding
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# openssl pkcs12 -in keystore.p12 -nokeys -out graylog-certificate.pem
Enter Import Password:
MAC verified OK
private key can export to pem encoding
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# openssl pkcs12 -in keystore.p12 -nocerts -out graylog-pkcs5.pem
MAC verified OK
Enter PEM pass phrase:
Verifying - Enter PEM pass phrase:
Graylog only supports pkcs8 private key with pem encoding
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# openssl pkcs8 -in graylog-pkcs5.pem -topk8 -out graylog-key.pem
Enter pass phrase for graylog-pkcs5.pem:
Enter Encryption Password:
Verifying - Enter Encryption Password:
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# head graylog-key.pem graylog-certificate.pem
==> graylog-key.pem <==
-----BEGIN ENCRYPTED PRIVATE KEY-----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==> graylog-certificate.pem <==
Bag Attributes
    friendlyName: 10.128.0.9
    localKeyID: 54 69 6D 65 20 31 35 31 30 37 36 35 33 30 36 39 31 35
subject=/C=IN/ST=maharastra/L=mumbai/O=graylog/OU=server/CN=graylogssl
issuer=/C=IN/ST=maharastra/L=mumbai/O=graylog/OU=server/CN=graylogssl
-----BEGIN CERTIFICATE-----
MIIDdTCCAl2gAwIBAgIEFTGHWDANBgkqhkiG9w0BAQsFADBrMQswCQYDVQQGEwJJ
TjETMBEGA1UECBMKbWFoYXJhc3RyYTEPMA0GA1UEBxMGbXVtYmFpMRAwDgYDVQQK
EwdncmF5bG9nMQ8wDQYDVQQLEwZzZXJ2ZXIxEzARBgNVBAMTCmdyYXlsb2dzc2ww
HhcNMTcxMTE1MTY1OTI0WhcNMTgxMTE1MTY1OTI0WjBrMQswCQYDVQQGEwJJTjET
pkcs8 private key file and x509 certificate are added in the graylog configuration file
Adding a self signed certificate to jvm trust store
original keystore copied with the following command,
cp -a "/usr/lib/jvm/java-8-oracle/jre/lib/security/cacerts" /home/graylogssl/bartwickelmaschine/create_self_signed_ssl_certs/cacerts.jks
Add the self signed certificate to keystore
keytool -import -trustcacerts -file graylog-certificate.pem -alias 10.128.0.9 -keystore /home/graylogssl/bartwickelmaschine/create_self_signed_ssl_certs/cacerts.jks
Version: 3
Extensions:
KeyIdentifier [
Trust this certificate? [no]:  yes
Certificate was added to keystore
To verify the self signed certificate added to the keystore
root@graylogssl:~/bartwickelmaschine/create_self_signed_ssl_certs# keytool -keystore /home/graylogssl/bartwickelmaschine/create_self_signed_ssl_certs/cacerts.jks -storepass changeit -list | grep 10.128.0.9 -A1
10.128.0.9, Nov 15, 2017, trustedCertEntry,
Certificate fingerprint (SHA1): 99:D2:A8:BC:13:DB:F4:DE:ED:CE:9C:63:A0:B4:A3:F5:28:6D:7E:E4
In order to pick the new trust store it has to be added in the jvm parameter
GRAYLOG_SERVER_JAVA_OPTS=“-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/home/graylogssl/bartwickelmaschine/create_self_signed_ssl_certs/cacerts.jks -Djavax.net.ssl.trustStorePassword=changeit”
Graylog server logs after logged into the Graylog UI
2017-11-15T17:22:12.590Z INFO  [JerseyService] Started REST API at <https://graylogssl:9000/api/>
2017-11-15T17:22:12.590Z INFO  [JerseyService] Started Web Interface at <https://graylogssl:9000/>
2017-11-15T17:22:12.595Z INFO  [ServerBootstrap] Services started, startup times in ms: {OutputSetupService [RUNNING]=21, BufferSynchronizerService [RUNNING]=31, KafkaJournal [RUNNING]=33, InputSetupService [RUNNING]=52, ConfigurationEtagService [RUNNING]=90, StreamCacheService [RUNNING]=90, JournalReader [RUNNING]=95, LookupTableService [RUNNING]=106, PeriodicalsService [RUNNING]=317, JerseyService [RUNNING]=19912}
2017-11-15T17:22:12.598Z INFO  [ServiceManagerListener] Services are healthy
2017-11-15T17:22:12.603Z INFO  [ServerBootstrap] Graylog server up and running.
2017-11-15T17:22:12.604Z INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2017-11-15T17:26:01.686Z WARN  [ProxiedResource] Unable to call https://104.198.57.170:9000/api/system/metrics/multiple on node <12bd94c6-bd85-4640-a0ea-22d439d08c7b>
javax.net.ssl.SSLPeerUnverifiedException: Hostname 104.198.57.170 not verified:
    certificate: sha256/9ExcxssbAdQSzmnw0rTS/JpBdENCKVYjpnqIYWEYOv8=
    DN: CN=graylogssl, OU=server, O=graylog, L=mumbai, ST=maharastra, C=IN
    subjectAltNames: []
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_151]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
Note:- I tried giving the both hostname & private IP address in rest_transport_uri but I am getting the error as “This site cannot be reached”. Using external IP only the Google cloud VM are able access in web interface.
Please kindly advice
Thanks,
Ganeshbabu R
if you use the following command:
it does not include the information you give above:
the call for the script should be something like:
bash create_ssl_certs.sh -h graylogssl -i 10.128.0.9 -i 104.198.57.170 -m
to include the public ip.
