Http to https redirect
After configuring our server to use https, it’s working perfectly. The issue is that when someone browses using http://server_address:9000, the connection doesn’t redirect to https and shows “The connection was reset”.
I thought I had followed all the steps. Am I missing something?
Any help would be appreciated.
Patrick
Hello && Welcome @patrickr
You can use either Apache, Nginx, etc… for redirect that would be your best bet.
That’s what I thought but wanted to make sure.
Thanks for the help!
