Http_response_code is not available
Hi, I am using Graylog 3.3 and using beats input for my apache logs. I also have Syslog TCP and UDP for the system logs.
However, these inputs do not give any HTTP response codes; http_response_code isn’t available on my filter fields. Am I missing something?
he @rdelacruz
you might need to create some kind of extractor for your logs. Graylog does not parse the logs automatically you need to create some kind of extractor or processing pipeline to create that.
