Hi
I am new to Graylog and trying to setup apache access logs and error logs. I have used ELK stack once where it go like Beats>Logstash(do some formatting of log using gork) > elasticsearch (update template to consider responsecode and responsetime as number)> Kibana
In Graylog what would you suggest the best approach to ship logs and format the logs. I see there is an extractor option avilable.
So if i send the logs from beats directly to graylog, would it extract and format the log and then store it in elastic search?
would I need to do anything in elasticsearch to consider the field and number?
with direct beat usage you are going to configure the beats on every system that sends the messages by yourself (or your configuration management) and with sidecar you can manage the configuration within the graylog web interface.
