Hi
my http port does not work , I have ping to my local ip 192.168.1.200 but I can not open the Graylog on my browser. could you please help me about it ?
thanks
Hi
Did you try with the port number?
http://192.168.1.200:9000
If that still doesn;t work then have a look at your server.conf and check you have the necessary parts filled out.
Thanks for your response I will chek it
what error you got?
You will need to set firewall rules for Graylog to work properly.
