Http 400 after upgrade to Graylog 5.2.3
I upgraded a working Graylog Enterprise installation today to the latest version 5.2.3. I am able to login into Graylog, but after that I get http 400 responses for all subsequent request. A valid license is installed.
I do not see any error message in the logfiles with a hint for the reason.
  • OS Information:
    Ubuntu 20.04.6
  • Package Version:
    I had a Graylog 5.1.6 installation using elastic search 7.2 and MongoDB 5.0.24 and tried to upgrade to Graylog 5.2.3. I updated using:
wget https://packages.graylog2.org/repo/packages/graylog-5.2-repository_latest.deb
sudo dpkg -i graylog-5.2-repository_latest.deb
sudo apt-get update
sudo apt-get install graylog-enterprise
Reboots, Restart, Scanning the logfiles
What version of the JVM do you have, and what do you get if you check the status of the Graylog service?
Thanks for your response.
I am using the included JVM, that ist “Eclipse Adoptium 17.0.9” or
openjdk version “17.0.9” 2023-10-17
OpenJDK Runtime Environment Temurin-17.0.9+9 (build 17.0.9+9)
OpenJDK 64-Bit Server VM Temurin-17.0.9+9 (build 17.0.9+9, mixed mode, sharing)
reported on the command line.
sudo systemctl status graylog-server.service
returns
graylog-server.service - Graylog server
Loaded: loaded (/lib/systemd/system/graylog-server.service; disabled; vendor preset: enabled)
Active: active (running) since Sat 2024-01-27 18:45:28 CET; 16h ago
Docs: http://docs.graylog.org/
Main PID: 63405 (graylog-server)
Tasks: 167 (limit: 38067)
Memory: 1.3G
and
sudo systemctl status elasticsearch.service
Loaded: loaded (/lib/systemd/system/elasticsearch.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2024-01-27 18:59:10 CET; 17h ago
Docs: https://www.elastic.co
Main PID: 67371 (java)
Tasks: 84 (limit: 38067)
Memory: 2.7G
CGroup: /system.slice/elasticsearch.service
└─67371 /usr/share/elasticsearch/jdk/bin/java -Xshare:auto -Des.networkaddress.cache.ttl=60 -Des.networkaddress.cache.negative.ttl=10 -XX:+AlwaysPreTouch -Xss1m -Djava.awt.headless=true -D>
sudo systemctl status mongod.service
mongod.service - MongoDB Database Server
Loaded: loaded (/lib/systemd/system/mongod.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2024-01-27 15:07:20 CET; 20h ago
Docs: https://docs.mongodb.org/manual
Main PID: 535 (mongod)
Memory: 270.5M
CGroup: /system.slice/mongod.service
└─535 /usr/bin/mongod --config /etc/mongod.conf
And I see 2 other messages in /var/log/graylog-server/server.log:
WARN [LookupTableService] Unable to load data adapter watchlist-mongo of type mongodb, missing a factory. Is a required plugin missing?
WARN [LookupTableService] Lookup table watchlist is referencing a missing data adapter 61ae04c47c4cd047cfc17221, check if it started properly.
But I have a second installation, same environment, with the same messages and that server ist running fine.
Out of sheer desperation and because I had run out of ideas, I set the maximum header size in Graylog from 8192 to 16384. And now it’s working again. A log entry would have been really helpful.
Do you mean http_max_header_size in server.conf?
Yes. Setting this to a higher value solved my problem.
Graylog is running behind an ALB in AWS and an ID-Provider. That results in a lot of headers. However, I do not know why it was working with Graylog 5.1.x and not with 5.2.3
That’s very interesting, it’s something we haven’t seen as of yet so it you could open a GitHub issue it would be helpful for the engineering team to look into.GitHub - Graylog2/graylog2-server: Free and open log management
