Graylog 2.5 to 3.0 Upgrade Failing
I am using the following instructions to upgrade to 3.0.
$ wget https://packages.graylog2.org/repo/packages/graylog-3.0-repository_latest.deb
$ sudo dpkg -i graylog-3.0-repository_latest.deb
$ sudo apt-get update
$ sudo apt-get install graylog-server
After I upgrade I see these errors in my graylog.log
2019-02-14T10:09:40.965-05:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=8d780330-306a-11e9-b79c-005056a85925, journalOffset=6999736356, codec=gelf, payloadSize=160, timestamp=2019-02-14T15:09:40.963Z, remoteAddress=/10.0.1.211:54120}
java.lang.IllegalArgumentException: GELF message <8d780330-306a-11e9-b79c-005056a85925> (received from <10.0.1.211:54120>) has empty mandatory “short_message” field.
at org.graylog2.inputs.codecs.GelfCodec.validateGELFMessage(GelfCodec.java:252) ~[graylog.jar:?]
at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:134) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:74) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191]
2019-02-14T10:09:43.111-05:00 ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=8ebe17c7-306a-11e9-b79c-005056a85925, journalOffset=6999736694, codec=gelf, payloadSize=158, timestamp=2019-02-14T15:09:43.100Z, remoteAddress=/10.0.1.65:49295} on input <59b04214f4c6071320a2b375>.
2019-02-14T10:09:43.111-05:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=8ebe17c7-306a-11e9-b79c-005056a85925, journalOffset=6999736694, codec=gelf, payloadSize=158, timestamp=2019-02-14T15:09:43.100Z, remoteAddress=/10.0.1.65:49295}
java.lang.IllegalArgumentException: GELF message <8ebe17c7-306a-11e9-b79c-005056a85925> (received from <10.0.1.65:49295>) has empty mandatory “short_message” field.
2019-02-14T10:09:43.750-05:00 ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=8f211f52-306a-11e9-b79c-005056a85925, journalOffset=6999736834, codec=gelf, payloadSize=160, timestamp=2019-02-14T15:09:43.749Z, remoteAddress=/10.0.1.65:49295} on input <59b04214f4c6071320a2b375>.
2019-02-14T10:09:43.751-05:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=8f211f52-306a-11e9-b79c-005056a85925, journalOffset=6999736834, codec=gelf, payloadSize=160, timestamp=2019-02-14T15:09:43.749Z, remoteAddress=/10.0.1.65:49295}
java.lang.IllegalArgumentException: GELF message <8f211f52-306a-11e9-b79c-005056a85925> (received from <10.0.1.65:49295>) has empty mandatory “short_message” field.
My web server is not starting and I can’t figure out why.
Your posted error is based on that a GELF sender is not sending valid messages
Did you read the upgrade Guide in the Docs and noticed the changed / removed configuration settings?
I missed that but even after updating my file all I get is a white screen when connecting to the web interface (I tried a second browser to make sure it wasn’t a cache issue).
Here is my cleaned up config.
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = xxxxxx
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = xxxxx
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
#rest_listen_uri = 10.0.1.xxx:9000
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
http_publish_uri = http://$http_bind_address/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
rest_tls_cert_file = /etc/graylog/server/cert.pem
# The PKCS#8 private key file in PEM format to use for securing the REST API.
rest_tls_key_file = /etc/graylog/server/pkcs8-encrypted.pem
# The password to unlock the private key used for securing the REST API.
rest_tls_key_password = xxx
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
rest_thread_pool_size = 64
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
http_bind_address = 10.0.1.xxx:9001
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#http_external_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#http_enable_cors = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
http_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
http_tls_cert_file = /etc/graylog/server/graylog-web-cert.pem
# The PKCS#8 private key file in PEM format to use for securing the web interface.
http_tls_key_file = /etc/graylog/server/graylog-web-key.pem
# The password to unlock the private key used for securing the web interface.
http_tls_key_password = xxxx
#http_max_header_size = 8192
#http_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
http_thread_pool_size = 32
# requires authentication.
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 75
outputbuffer_processors = 50
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
message_journal_max_age = 48hr
message_journal_max_size = 50GB
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
transport_email_hostname = mailhost.corp.com
transport_email_port = 25
transport_email_use_tls = false
#transport_email_subject_prefix = [graylog]
#transport_email_from_email = graylog2@corp.com
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
ldap_connection_timeout = 5000
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
I figured it out, I am beyond idiotic. I needed to change the the http_publish_uri to include the port. Then everything came back online.
Naww, you’re awesome! You figured it out didn’t you? :slight_smile:
