How to use event definition description to send an alert to slack
Also, nothing
Nothing, hmm.
Let’s try and dump the model data in a different way then. You can configure a simple HTTP notification - it should contain all the available event fields. You can use e.g. https://webhook.site/ to obtain a test URL.
I guess I’ve understood your idea to test another way notification way. I testes exactly my event definition in another type of notification. And I’ve got a field
So only the Slack notification is failing to display event_definition_description?
That looks like a bug. Investigating …
I reproduced your issue in 5.0.
In 5.1 and later it does not reproduce.
Please upgrade to a supported version. Support for 5.0 ended 7 months ago (30 Oct 2023)
Thanks for advice, we will try
