How to use event definition description to send an alert to slack
Hello, guys.
I tried to add description of event for vizualising it in the slack’s alert.
I used Event Definition Metadata which I found here Alerts
But there was nothing in my alert. Screenshots of my workflow in 3rd point
  • OS Information:
    5.0.10+40c8c33, codename Noir
  • Package Version:
Looks good to me. Can you run it again with debug logs turned on? That will log the template and data that is being used to generate the message. Maybe that will shed some light.
Hello. Can give it you using only WEB interface? I have’t an access to server via console
You can set log level in the UI on the system/logging screen.
Unfortunately, I don’t have option “Cluster support Bundle” like you send on screenshot before
Ignore that. I am referring to the dropdown next to Subsystem: Graylog. Currently showing info - switch that to debug.
I did. What I should to do after?
Search the log for a message like
customMessage: template = {} model = {}
The placeholders will be replaced by your data. Hoping that will provide a clue.
Unfoturnately, nothing. What i’m doing wrong?
Also I’ve tried to find like this
Sorry, I am referring to Graylogs server logs, not the ingested log messages.
oh, do I to see them it in graylog servel log wich exist on the path ?
/var/log/graylog-server/server.log
yes - that’s what I meant
I’ve got a logs. From all of ours servers. But there is about 1Gb. Which messages I should find?
Nothing
My mistake - the {} are actually the placeholders that get replaced.
Does a search for just customMessage: turn up anything?
Unfortunately, nope
There was two messages which I’ve send to my #test-notify channel. Below, all what I’ ve found:
OK, that wasn’t helpful.
Please do another search for this debug output: the custom message model data is
