Event definitions not create alerts
Im new graylog, so im trying the setup my first Event definition but it doesn’t generate any alerts.
  • OS Information:
    Ubuntu 20.04
  • Package Version:
    4.2.9-1
If someone have can fix it please. Thanks.
Hello && welcome @mmaslouj
Judging from that screenshot, I’m unsure what the issue is. Does the word Failed get searched at all?
Testing, try to increase the search time from 1 minute to like an hour see if it will come though in the right pane.
Also, maybe use something like this with quotes.
"Failed"
or
"failed"
Hello @gsmith,
You right, i was searching from events for last 1 min.
Now it start show me result in filter preview but still no notification triggred.
Now i start getting events but it show only the previous actions, the “Next timerange” not change by time.
I was just stating about increasing the search time to insure messages could be scanned, but 1 minutes is good for search time. if you don’t see it in one minute you may need to wait.
Next would be you notification settings.
Example:
Summary should look something like this.
