How to use a commerical cert
I have bought a commercial certificate from Sectigo. I would like to use the commercial cert that we purchased. They have provided us the following files:
  • Your PositiveSSL Certificate - graylog_ucs_louisiana_edu.crt
  • Your Apache “bundle” file - graylog_ucs_louisiana_edu.ca-bundle
These are my following questions:
  1. What are the steps to import this commercial cert and use https?
  2. Where in the documentation can I find the steps pertaining to using a commercial cert and enabling https?
  • OS Information: RHEL 9.6
  • Package Version: Graylog Open 6.2
I am confused which documents to follow as I don’t have a pfx certificate according to this instructions:
How-To Guide: Securing Graylog with TLS
I would really appreciate if the community can provide some step by step instructions on how to enable https and import the commercial cert.
Thank you in advance! :folded_hands:
UPDATED
I have followed every steps from the documentation below :
Secure Graylog Interface with TLS
Following every steps in the documentation I’ve generated the following files, screenshot below:
If the picture is not clear enough, these are files that have been generated following the steps:
graylog.csr ; graylog_ucs_louisiana_edu.crt ; keypair.key ; public.cert.pem public.chain.text.pem ; public.text.pem ; graylog_ucs_louisiana_edu.ca-bundle graylog_ucs_louisiana_edu.pfx ; private.key ; public.chain.pem ; public.pem
However, I am stuck at this step (Import the Certificate Files into the Java Key Store) below, screenshot provided:
My question right now is how can I get the enterpriseRootCA.cer as mentioned in the steps?
I do not have any files with .cer
Also, in this step Import the Root CA and Intermediate certificates:
sudo keytool -importcert -keystore /etc/graylog/graylog.jks -storepass changeit -alias cachain -file /etc/graylog/enterpriseRootCA.pem
What is changeit?
