I am trying to send SQL DB logs to Graylog. Does anybody has an idea on how to send DB logs to Graylog?
If it’s just a file - then you can use Filebeat.
It’s the table we have that the app writes into.
I can suggest 2 ways
Thanks @zoulja for the suggestions,I will try both the options.Please let me know if there is any guide or documentation on sending DB logs to Graylog.
Hi @zoulja ,I tried the second option.I am using nxlog.conf to send the DB logs to Graylog. Below is the nxlog.conf.
Panic Soft
#NoFreeOnExit TRUE
define CERTDIR %ROOT%\cert
define CONFDIR %ROOT%\conf
define LOGDIR %ROOT%\data
define LOGFILE %LOGDIR%\nxlog.log
LogFile %LOGFILE%
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
<Extension _syslog>
Module xm_syslog
</Extension>
<Extension _charconv>
Module xm_charconv
AutodetectCharsets iso8859-2, utf-8, utf-16, utf-32
</Extension>
<Extension _exec>
Module xm_exec
</Extension>
<Input mssql>
Module im_file
File "D:\Program Files\Microsoft SQL Server\MSSQL14.MSSQLSERVER\MSSQL\Log\ERRORLOG"
Exec convert_fields('UCS-2LE','UTF-8'); if $raw_event == '' drop();
</Input>
<Input reading_integer_id>
Module im_odbc
ConnectionString Driver={ODBC Driver 17 for SQL Server}; Server=MSSQL-HOST; Trusted_Connection=yes; Database=TESTDB
IdType integer
SQL SELECT RecordID AS id, * FROM dbo.test1 WHERE RecordID > ?
Exec delete($id);
</Input>
<Output graylog>
Module om_tcp
Host Server IP
Port XXXX
OutputType GELF TCP
#Use the following line for debugging (uncomment the fileop extension above as well)
#Exec file_write("C:\\Program Files (x86)\\nxlog\\data\\nxlog_output.log", $raw_event);
</Output>
<Route mssql>
Path mssql => graylog
</Route>
<Route reading_integer_id>
Path reading_integer_id => graylog
</Route>
I have created 2 inputs,1 to send the DB error logs and 2 to send the DB Table logs.
I am getting the below error in nxlog
2019-12-04 17:16:29 ERROR Invalid OutputType 'GELF TCP' at C:\Program Files (x86)\nxlog\conf\nxlog.conf:39
2019-12-04 17:16:29 ERROR module 'graylog' has configuration errors, not adding to route 'mssql' at C:\Program Files (x86)\nxlog\conf\nxlog.conf:46
2019-12-04 17:16:29 ERROR route mssql is not functional without output modules, ignored at C:\Program Files (x86)\nxlog\conf\nxlog.conf:46
2019-12-04 17:16:29 WARNING no routes defined!
2019-12-04 17:16:29 WARNING not starting unused module mssql
2019-12-04 17:16:29 WARNING not starting unused module graylog
Please suggest what should be the output type for sending DB logs.
Never tried nxlog, but I believe Input type must be Beats, not GELF
Thank you.I will try with Beats.
