I would like to know how can I search for log messages with a custom properties containing a field named “Main Status” and value “Starting Process”…
how can i do that?
how can i do that?
Is the “main status” field being extracted? i.e. is there a dedicated field or it or is it within the bulk “message field”?
Did you read the Documentation on that?
http://docs.graylog.org/en/2.4/pages/queries.html
is something not clear on that?
Jan, instead of being a dick about it, why don’t you point something friendly, like “why dont you try this query
? for more info about it, check documentation’s section X”
Its a dedicated field. It’s content is a JSON… i thought it was kinda default field on the platform… I’m used to Application Insights, and on it the query would go something like where CustomProperties.SubField = Value
Leonardo if you have performed extractions against the logs to ensure dedicated fields were created for that log type as needed (http://docs.graylog.org/en/2.4/pages/extractors.html) then you can run a search in this format Main Status:Starting Process
. That requires Main Status to be it’s own field in graylog though (not just in the raw log that came in.
