How to Recieve input from remote host
Hi.
i have problem with graylog.
i want to send log data from remote host or another computer.
i tried put ip address of my host in bind address. but its failed. i did firewall configuration.
what should i do in my graylog?
many thanks.
are you using rsyslog ? or what ? show us the configuration ?
run wirshark and tcpdump to see if the port are open and to see package in the network ?
im using syslog. the config of graylog? or what?
Please post the complete configuration of Graylog, the inputs you’ve created, and the network setup in your environment.
:arrow_right: http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
