How to get RPM packages for server without direct access?
Hello
I can not search fresh rpm files on https://packages.graylog2.org/el
Your instruction for use https://packages.graylog2.org/repo/packages/graylog-2.3-repository_latest.rpm is not suitable for me. My server has not direct internet access.
But I can download packages from 3rd machine.
Please help me with direct links to graylog-2.2 (and 2.3) rpm packages for x86_64.
Thank you.
You can download the RPM packages directly from https://packages.graylog2.org/el/stable/2.2/x86_64 or https://packages.graylog2.org/el/stable/2.3/x86_64 respectively without using YUM.
Hello.
Packages downloaded.
Thank you for support.
