How to find a node
We use Graylog 2.5.2.
Graylog gives the notification:
nput 5c9b51d5e58a1a690a2cb306 has failed to start on node 0a1b4334-e7c4-4d0c-a382-23af10df09d4 for this reason: »Permission denied.«. This means that you are unable to receive any messages from this input. This is mostly an indication for a misconfiguration or an error. You can click here to solve this.
How can I find out which node that is.
I need the IP-Address or domain name.
Go to the UI System > Nodes and in the overview you can see the Nodes with their UUID.
