Groucou
(Arcocide)
September 12, 2017, 10:35am
1
Hi everyone,
I would like to add pipeline to exclude automatically some logs ?
I think that I must use pipeline but I don’t know how ! I’m just beginning Graylog
For example I would like to exclude log with such host or source.
For information I receive all logs with JSON format.
jochen
(Jochen)
September 12, 2017, 1:16pm
2
Yes, you can use the processing pipelines for that, see http://docs.graylog.org/en/2.3/pages/pipelines.html for details.
You can stop processing messages with the drop_message() function.
Groucou
(Arcocide)
September 12, 2017, 1:39pm
3
Ok thanks you for your answer but could you give me one example ?
I 'm not a good dev
I try for drop message :
rule "drop cronjob"
has_field(“application_name”) && to_string($message.application_name) == "CRON"
drop_message();
Is it correct for you ?
Groucou
(Arcocide)
September 12, 2017, 2:02pm
5
Ok thx and for my new pipeline
pipeline "My new pipeline"
stage 1 match all
rule “drop message”;
jochen
(Jochen)
September 12, 2017, 3:00pm
6
Looks fine.
Why don’t you just try it out instead of asking if it’s fine?
